does your voltmeter move alot?
Old Jan 14, 2008 | 08:36 PM
igo4bmx's Avatar
My voltmeter shifts from 12-14 volts when i just turn the wipers on, or a turn signal.
Does this happen to others too?
using oem mr gauge to read volts.
Old Jan 14, 2008 | 08:38 PM
wizzo 8's Avatar
Well usually the voltage will drop when something goes on but it sould go back up to normal voltage after a couple of seconds.
Old Jan 14, 2008 | 08:40 PM
igo4bmx's Avatar
when you put your wipers on, does the voltage shift in relation to the wiper speed?
in my civic it never did this.
Old Jan 14, 2008 | 08:43 PM
wizzo 8's Avatar
I dont have a factory volt gauge its aftermarket. I will check tomorrow with my gauge though. What you said makes sense though.
Old Jan 14, 2008 | 09:18 PM
legato's Avatar
I notice my voltage dips down to roughly 12V when I blast my A/C...This should be normal as typically when you start a motor, voltage dips as the motor draws a load of current...Same would apply for the wiper blades as I assume that is motor driven...
Old Jan 14, 2008 | 09:20 PM
saev's Avatar
mine does. same with the blinkers. I have the BR mini battery.
I've also noticed the needle twitching at idle.
W_evo8's Avatar
mine stays at 14.2-14.5 always aslong as its running, reading from greddy turbo timer.
Old Jan 14, 2008 | 09:23 PM
fromWRXtoEVO's Avatar
It will move accordingly with the loads(A/C, high beam, fan, etc). When I had the MR it occurred and now that I have another Mitsubishi voltmeter kit from a Evo MR on my Eclipse I still have the same issue. It moves when a significanmt load in being applied. So nothing to worry about.
Carlos
Old Jan 14, 2008 | 09:43 PM
evoix10's Avatar
yeah mine moves a lot. anything from the a/c to the wipers makes the needle move but it goes back to 14ish in like a second. the needle moves to the bass of the stock sound system. i think this is normal and not a problem
Old Jan 15, 2008 | 03:35 PM
BBS's Avatar
BBS
It shouldn't shift from 12-14 constantly. It should stay within the 14-13 volt range.
Old Jun 9, 2015 | 11:14 PM
Riomr13's Avatar
Any body found the solution for this problem????
Old Jun 11, 2015 | 10:28 AM
MechTech's Avatar
Mine used to move slightly when the bass hit playing music loudly. I took my battery out and desulfated/charged it up. Hasn't done it since.
Old Jun 13, 2015 | 09:30 AM
Riomr13's Avatar
how can I do the desulfate to the battery
Sheasta
Dec 23, 2015 07:48 AM
mrm95
Jul 29, 2015 05:06 PM
pcguru2000
May 29, 2015 12:02 PM
maxroach
May 24, 2015 12:43 PM
SCREAM8
Apr 30, 2015 06:03 PM
