Turbo Spool? just to be safe
Old Jan 31, 2008 | 08:22 AM
gottf257's Avatar
Hey guys i recently swapped my stock dp and cat with an ams dp and test pipe. ever since, ive noticed the turbo spool being WAY louder and much higher pitch. i thought i would get a little better spool from the extra flow, but just wanted to make sure what i was hearing was safe. i also have an aem short ram, and greddy rs bov
Old Jan 31, 2008 | 08:25 AM
TeStUdO's Avatar
You intake makes turbo spool louder. If it sounds like a whistle, it might be a boost leak. Do a boost leak test.
Old Jan 31, 2008 | 08:26 AM
Blizzackk's Avatar
Did you install your intake and bov at the same time as the exhaust or before?
The intake and bov will greatly increase the amount of sound of the spool
Old Jan 31, 2008 | 08:27 AM
evoracer12's Avatar
Yea you are fine. Just make sure you put the exhaust on tight so you dont have an exhaust leak. I wouldnt put the aem short ram on unless you are getting a flash or tuned. and in regards to the greddy rs bov, just make sure you recirculate back into the intake or you will have problems. have fun with the car!
Old Jan 31, 2008 | 09:24 AM
gottf257's Avatar
i first had the intake installed over a year ago, then 6 months later did the cat back exhaust. after that did the downpipe and testpipe, then 2 weeks later the bov.
wierd thing is tho is im getting the same almost less sound out of the greddy bov then i was with the stock bov
Old Jan 31, 2008 | 09:28 AM
90GSX-03EVO's Avatar
In my opinion, that's a good thing. Nobody likes a ricer.
cmross13
Nov 7, 2012 10:11 AM
RalliMark
11
Jul 16, 2012 03:20 AM
pwdrtoastman
14
May 29, 2011 04:15 AM
BEISSEN
Jul 9, 2010 06:38 AM
IOevo
17
Feb 12, 2005 03:35 AM
