i need help
Old Feb 4, 2008 | 07:52 PM
reimundo's Avatar
i need help
I have a completely stock 03 evo with 28,000 miles . Car starts to cut out on past 4000 rpm's . I think it is a boost leak , but i don't know . What do you guys think ? I just did a oil change and spark plug change . There is no cel light, and i checked it with OBD2 scanner and there is no codes . The problem with the car just started happening after a long drive home.
Old Feb 4, 2008 | 07:54 PM
evo8426's Avatar
what do you mean it starts to cut out? like the car cuts off or the car feels like it loses all power at 4000rpm? or what? make sure the snorkle on the intake has not come up
Old Feb 4, 2008 | 07:58 PM
wizzo 8's Avatar
Does it cut out after 4k at WOT or under normal load?
Old Feb 4, 2008 | 08:02 PM
reimundo's Avatar
at it cuts out WOT .
Old Feb 4, 2008 | 08:04 PM
reimundo's Avatar
yeah it feels like it is losing power at WOT .
Old Feb 4, 2008 | 08:05 PM
evo8426's Avatar
definately make sure the clips on the snorkle to the intake are pushed down because that has happened to me before and caused the same problem
Old Feb 4, 2008 | 08:27 PM
reimundo's Avatar
what is a snorkle ? sorry i it's my first evo . is it on the air intake ?
Old Feb 4, 2008 | 09:19 PM
chaotichoax's Avatar
the piece that leads to the intake box
there are two black push pins that hold it to the radiator shroud...if the come out the duct will not function properly
Old Feb 4, 2008 | 09:28 PM
reimundo's Avatar
well it looks a little loose on the top. i will check it out .
Old Feb 4, 2008 | 09:31 PM
reimundo's Avatar
what else could it be ?
Old Feb 4, 2008 | 10:07 PM
Warrtalon's Avatar
It's your clutch slipping.
Old Feb 4, 2008 | 10:12 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
do the rpms continue to go up after the feeling of loss of power? If so warr might be right
Old Feb 4, 2008 | 10:18 PM
jezefink's Avatar
Check the injectors. Make sure they are seated right and all metal clips are in. If an injector is loose that could be ur problem
