HID not working HELP
Old Feb 10, 2008 | 08:51 AM
evoix10's Avatar
Ok my OEM ballast burned out so i got an after market ballast. The wiring was simple, just two wires that connect to the two existing wires where the OEM ballast plugged into.
Before I did any soldering the plugged the headlight assembly into the car to test it. Everything was fine. So i soldered it and half way through putting the car back together I realized I should test it one more time...this time the bulb wouldn't light!
So after pulling everything back apart, I tested the headlight again. The bulb looks like it wants to light but it just buzzes, attempts to light, and go out.
I don't know what the problem is. I've searched here and on the internet and it sounds like it might be the bulb. I don't want to pull the other bulb out to test because anyone who has removed the headlights knows how much a pita it is.
Anyone with advice or experience with this is welcome.
Thanks you
Old Feb 10, 2008 | 11:01 AM
evoix10's Avatar
Anybody?
Old Mar 21, 2010 | 08:43 PM
huevosrancheros's Avatar
pull out the other hid bulb from the other side and test that one out.
Old Mar 22, 2010 | 08:05 AM
IrightI's Avatar
Originally Posted by style619s
i already did that and nothing but im getting a volt meter in couple of days because i think i might have a short... when i turn my brights on my drivers side bright dont come one and drivers rear turn signal stays on the whole time....
I'm almost sure you have a bigger problem my friend.
https://www.evolutionm.net/forums/in...s-how-fix.html
Old Mar 22, 2010 | 05:45 PM
evoix10's Avatar
WOW! someone went digging through old threads lol
I fixed the problem a long time ago. My problem was the the OEM ballast had a grounding strap that ran to the ballast and to somewhere inside the headlight. Well when i tested the hid the first time the strap wasnt touching the aftermarket ballast and it worked. But when i tested it the 2nd time when putting it together, the strap was touching the case which caused the problem.
So i guess i learned somehow not to use the grounding strap. Assuming the grounding strap is attached to the chassis ground, the aftermarket ballast probably wont work if its touching anything metal.
So dont ground the case of the ballast.
GL
Old Mar 22, 2011 | 12:14 AM
Srt4...'s Avatar
I'm happy i searched and searched.... I just had the same issue last nite and I believe this is my answer casue I never reconnected the ground...
llDemonll
30
May 22, 2018 04:07 PM
Evo47
Apr 22, 2016 08:11 AM
thatdudety
Sep 11, 2013 03:25 PM
08GTSMayhem
70
Apr 9, 2013 12:28 PM
Rustyreno
May 5, 2010 07:30 PM
