Evo IX oil
Old Sep 1, 2009 | 05:16 PM
  #46
Berts24's Avatar
Originally Posted by 90GSX-03EVO
But the engine would be cold if you waited for 2 hours. You're supposed to check your oil when the engine is hot.
This has always me but when the engine's hot then you're reading would be off because not all the oil has settled down to the pan right??
Old Apr 22, 2010 | 08:45 PM
  #47
MR.IX.SE's Avatar
Let it sit about 2 hours before checking your oil.
Old Apr 23, 2010 | 12:13 PM
  #48
dambikeracer's Avatar
CAPACITIES:
Engine, with filter..........5.7 quarts
Cooling System, Turbocharged Initial Fill..........6.4 quarts
Manual Transmission, 5 SPD - W5M51..........4.7 pints
Manual Transmission, 6 SPD - W6MAA..........6 pints
Differential, Rear..........1.1 pints
Transfer Case, ..........1.3 pints
I use 5.5 QT in the motor and .2 in the filter. You guys may need a little bit more oil!
Kevin Knight
Nov 26, 2016 08:56 PM
fast03evo
Jun 14, 2015 05:33 PM
mitsuevodriver
26
May 13, 2014 12:01 AM
05evoGSR
12
Sep 13, 2007 06:27 AM
Inprogress
Jun 30, 2006 06:29 PM
