what is my 1/4 time
Old Mar 4, 2008 | 09:34 AM
  #91
AlexTwinTurbo's Avatar
I think that's driving and practice, just for information, that day I made 11 passes...
#1 - 10:39 am - 14.6 @ 93.35, 2.46 60 ft, missed 3rd, lol, no drop clutch
#2 - 10:45 am - 13.7 @ 105, 2.47 60 ft, no drop clutch
#3 - 10:50 am - 13.63 @ 105, 2.366 60 ft, no drop clutch
#4 - 10:56 am - 14.12 @ 104.6, 2.596, bad driving again, lol
#5 - 11:02 am - 13.97 @ 105.8, 2.588 60 ft, no drop clutch
#6 - 11:08 am - 13.00 @ 106.33, 1.93 60 ft, Finally I started to drop the clutch...
#7 - 12:09 pm - 13.02 @ 106.38, 2.00 60 ft
#8 - 12:14 pm - 13.02 @ 107.15, 2.019 60 ft
#9 - 4:20 pm - 13.10 @ 106.9, 2.080 60 ft
#10 - 6:07 pm - 12.57 @ 108.21, 1.797 60 ft, The Magic Pass!!!!
#11 - 7:01 pm - 12.75 @ 107.09, 1.81 60 ft, Not good enough
See that's there no magic in there, just practice, remember the car was 1 month purchased with 700 miles and warranty bumber to bumper, don't attempt this at home...lol
Old Mar 4, 2008 | 03:11 PM
  #92
lemmonhead's Avatar
nice impovement man, good job cutting down your time all in 1 day.
I probably wont be able to do that.
Old Mar 4, 2008 | 03:32 PM
  #93
chrisevo8's Avatar
the only way to find out what you will run is just to run. I went to the track for the first time this past sunday with one goal in mind. Get into the 12's with a stop light roll out. Best was 12.6 @ 113. For my final run decided to use my 2 step and launch cause my stock clutch held up great with 52 k on it. Ended up with
12.08@114. My friend with a 9 mr se ran 12.38 @ 109 with full turbo back, boost controller, and k&n drop in. His numbers were 336 and 350 on AMS (Gaithersburg) dynojet.
Old Mar 4, 2008 | 03:35 PM
  #94
HeLLA JDM y0's Avatar
jesus frickin' christ. bench racing FTL. you should all know that.
Old Mar 4, 2008 | 03:37 PM
  #95
bigric09's Avatar
Originally Posted by Wiznaz
the difference betweeen trapping in the 120's and our 112-113s is probably over 100whp/weight reduction which I don't see possible in those mods you listed without spray or something. But you don't need to trap in the 120's to run mid 11s.
if you are standard weight to just pulled out the spare tire weighted evo.... you almost have to trap 118 to 120 or better to hit 11.5 or better. on our track, trap speeds of 115 to 120 with a 1.7 60ft yield you about 12.0 to 11.5
Old Mar 4, 2008 | 06:27 PM
  #96
W_evo8's Avatar
practice practice practice
Old Mar 24, 2008 | 04:33 PM
  #97
blackdemon's Avatar
Originally Posted by bigric09
you will probably not see 12.5 .... i think the best i ran with a drop in filter, TBE, MBC and dynoflush tune was 12.8 maybe a 12.5 and that is way more modded than you and i was cutting 1.70 60 ft's
I ran a 12.6 @ 108MPH my mods are in my sig. No track experience whatsoever.
Old Mar 24, 2008 | 08:41 PM
  #98
TakaseEVOIXSE's Avatar
just look at your trapspeed on your timeslips... that will tell you right away if 1)you are making enough power for a 12sec timeslip (usually upwards of 106mph) and 2) how bad your driving is affecting your ET (also look at your 60ft)
lets say you trap around 108mph... but run a 13.5. Look at your 60ft because it had to suck and it was your driving that yeilded the slow ET not the car. w/ similar basic mods i ran a 12.5 and from my 60ft, i had alot left in the 60ft... just get out to the track... only way you'll know.
Old Mar 24, 2008 | 11:46 PM
  #99
evotuner04's Avatar
15 Year MemberLikedLoved
it doesnt take much to get an evo into 12s huh?
Old Mar 25, 2008 | 03:47 AM
  #100
blackdemon's Avatar
Like i was told by a freind. It takes some people longer than others to learn on how to launch a evo.
Old Mar 25, 2008 | 11:05 AM
  #101
evotuner04's Avatar
yeah id say im a pretty good driver....ive done numerous launches....some bad, some damn good.....so i'll see what i put down this spring
Old Mar 25, 2008 | 11:54 AM
  #102
EvoDom's Avatar
12.8-13.6 depends how u drive i went 12.6 with the following
3.5"TBE, upper intercooler pipe, short throw, intake, samco BOV, turbo xs boost controller, boost at 20lbs, and not even tuned yet!!!...I can drive thou
Old Mar 25, 2008 | 12:21 PM
  #103
dsmfan95's Avatar
If you have to ask, you probably won't do spectacular.
Old Mar 25, 2008 | 12:34 PM
  #104
Boostin4g63's Avatar
when u goin to the track? run it and post up the time slips. let us know. best of luck man
Old Mar 25, 2008 | 12:57 PM
  #105
Arkitek's Avatar
good times...i missed third twice during 4 runs my first time..could only manage a 13.2 at best becuase of missing third....both low 13 passes i missed third actually...my trap times say i should have had 12s though
