I Hate Myself Right Now!
Old Feb 22, 2008 | 02:17 PM
chaotichoax's Avatar
right next to the radiator being the ACD fluid reservoir?
I think it's red I'm not really search
if so...are your three ACD lights on, on the dash?
sharkm87's Avatar
he avoiding the question ....well he said he always go out in snow, so i would assume he has on snow tires..
hopefully you didn't hit the brake when the back end started to go out.
Old Feb 22, 2008 | 02:20 PM
Chemwarrior's Avatar
There goes another one. It seems like every other thread on here is an accident thread. I feel for you though. I concur what the masses say about going through your insurance. It only makes sense.
heel2toe's Avatar
I stated above that i have installed snowtires. And yes i didnt hit the brake as I have been in that position before and know it would send me more sideways. Right as i countersteeed i was at the curb. I know that with our cars im better off getting back on the gas to pull myself out of the slide but there was just no room for that
Old Feb 22, 2008 | 02:23 PM
heel2toe's Avatar
Thanks for that ill go check that out right now. Thats what i thought it was by process of ililimination. The resevoir is empty now. The better questions though is where is it leaking from. Hopefully its just some type of line rather than a mechanical piece. The damage was sustained in the front more towards the driverside.
Old Feb 22, 2008 | 02:25 PM
sharkm87's Avatar
yea, after i posted, your post appeared above it....i spent the few minutes actually reading threw everything ...
good luck to you bro, i know when that happened to me luckily i had alot of road to collect myself.
Old Feb 22, 2008 | 02:28 PM
dexterdizzle's Avatar
my buddy a few years back wrecked his ralliart filed insurance claim and he had the accolade body kit ordered. He just went to the body shop and told them he wanted the bodykit and they ordered it instead of the stock pieces/ Not sure if every shop will do that but. . .
Old Feb 22, 2008 | 02:29 PM
heel2toe's Avatar
sorry i didnt realize that. And I dont mean to sound like an *** and if I have please excuse me. Today just hasnt been a good day for me.
Old Feb 22, 2008 | 02:30 PM
Tnnrx7's Avatar
But really sorry to hear about that man.
You pay hundreds and hundreds of dollars a month for insurance, why would you not want to report it?
Old Feb 22, 2008 | 02:34 PM
FLOW1's Avatar
Good luck with the car. Sucks but anything can happen.
shivaswrath's Avatar
don't drive ur car, the RED FLUIDS that are leaking are fluids for the ACD. . .
Old Feb 22, 2008 | 02:40 PM
eckorex's Avatar
red fluid likely = busted ACD pump
dolla dollar bills yall!
Old Feb 22, 2008 | 02:45 PM
MR. EVO MR's Avatar
you were going 5-10 mph but once you start to swing it speeds up, it could of ben 20mph on impact?
sorry to hear your loss, just f it and call the insurance company.
Old Feb 22, 2008 | 02:48 PM
bigboybusa's Avatar
Sounds like $6000+ of damage... Bents strut tower bar, body is tweeked! Make sure when you take it to get fixed that they check all the suspension on that side, the lower A-arms are aluminum and tweek very easily!!! Also check all your motor mounts for damage. I use to do insurance adjustments, and had adjusted a Evo that hit a curb at 40mph, his car total was 4500 but had a 2500 suppliment because the suspension on one whole side had to be replaced...
Good lock on getting your car fix!
Old Feb 22, 2008 | 03:24 PM
heel2toe's Avatar
Thanks the car is home safely in my garage. I just took some pics and im attempting to put them up. Does a leak in the ACD fluid have a direct correlation to my ACD pump? Is the pump located inside the bumper on the driver side because I have a pump which although it isnt hanging i can tell its loose?
My strut tower bar isnt bent theres a bar spanning across the front of the car that the bumper and radiator tie into. That piece is bent. It seems like the more i go down to look at it there the more i find wrong with the car! ill try to get the pics up asap.
