Please Help, Shifter bent to the right
Old Mar 10, 2008 | 07:50 PM
tdz16's Avatar
I'd really just check the base for any damage that would keep it shifted over, especially since the trans was rebuilt. Let me know how it works out.
~Tom
Old Mar 10, 2008 | 07:59 PM
fox2boost's Avatar
dont forget to twist after you stab. +1 on looking it over again, i would take it all apart and look over everything carefully. it probably something realy stupid.
Old Mar 10, 2008 | 08:17 PM
Johnboy1065's Avatar
yeah I've got it all apart right now. I've noticed that it gets resistance mostly in 3rd and 4th. which means the shift linkage cable that determines those two gears might be the problem. I'm not seeing any damage though. Might just try and replace that whole cable. it seems like the other cable is fine though.
if you have the console open it is the shift linkage cable on the right
Old Mar 10, 2008 | 08:26 PM
Old Mar 10, 2008 | 08:49 PM
eehjay's Avatar
It kinda sounds like maybe one of the bushings in the shifter base could have popped under the base. I mean with enough force you might be able to force that rubber under it. Right? I'm just trying to remember from when I changed mine out.
Old Mar 10, 2008 | 10:28 PM
Jameson_IXMR's Avatar
If you disconnect the cables from the in-cabim shifter base. So the gear lever is free moving. Does it move in the normal positions? The gear shifter is quite a neat little invention, perhaps one of your springs are broken? I have mine taken apart right now actually, I can go take a photo of the base and you can compare the alignment. I have a 6 speed though, but it should be similar.
Old Mar 10, 2008 | 10:31 PM
Yes, I just did that and it was able to move around freely. if you could take a pic tha'd be great to kinda give me something to go by.
Old Mar 10, 2008 | 10:39 PM
Bexa20's Avatar
my suggestions is if you have a friend that has an VIII as you do ask him to stop by your house one day disassemble the console on your and his car and compare everything side by side, including linkage by the transmission. Maybe you will be able to see something that you cannot now.
Old Mar 10, 2008 | 10:56 PM
yeah tha'd be a good idea. I'll prolly try that sometime.
Old Mar 16, 2008 | 07:18 AM
FL_SilverEvo8's Avatar
Originally Posted by Big Shooter
bent shifter? yeah happened to me once. thats why hookers are bad my friend. shot of penicilin & that burning sensation will be taken care of
Old Mar 16, 2008 | 07:24 AM
check to see if you still have that white half moon peace that goes under the rod to pull it up and down? i had some what the same prob. i was missing that white half moon peace and after a while the nub that the moon peace was on wore out and then i couldn't go into 1st or 2nd gear. if i rember i will take a pic and posted it so you know what i am talking about.
Old Mar 23, 2008 | 05:19 PM
could anyone tell me the part number of the shift linkage cable that I pointed to in the picture???
is it MN107670 ??? I think thats it but am not for sure since there are not pictures of it.
Old Jul 31, 2009 | 09:27 PM
visyoual's Avatar
I installed an agency pwr short shifter and putting it back together, parts 4and5 were upside down so that i had to twist them, then get the spherical bearing clipped in... should parts 4 and 5 even be upside down when you go to reattach the shifter???
Old Jul 31, 2009 | 10:04 PM
fuzzydoodle's Avatar
It would seem like it should be the plate. Weird though, you replaced it?
Even in the diagram number 11 looks pretty intricate, alot of parts to bend....even slightly would give you a problem.
Old Aug 5, 2009 | 07:33 AM
visyoual's Avatar
i have a thread started about a shifter issue i was having.. possibly some helpful posts in it.
rEVoLed
Feb 20, 2016 02:50 PM
THE4TH
13
Dec 29, 2015 07:58 AM
Grip Master
Apr 20, 2011 09:33 AM
joseph143
Jan 25, 2011 01:29 PM
jMatt
Lancer Troubleshooting
May 12, 2006 12:50 AM
