Fuel pumps
Old Mar 18, 2008 | 02:45 AM
mitdrx's Avatar
Fuel pumps
After researching numerous threads it appears that a IX fuel pump may work for my mods. Evo 8-drop in filter-mbc-IX turbo-gsc stage 1 cams-tbe. All the threads I have read say that this pump will handle most bolt ons. I know about the tuning head room of the walbro. But I dont drag the car and the most it would ever see is 22psi on 94oct. I have had numerous other walbros on 240sx and gsx. It seems like fuel mileage dwindles with these pumps as pressures are slightly increased. Can I get away with jsut the IX pump?
Old Mar 18, 2008 | 02:51 AM
dxbevo9's Avatar
bro,,, just invest in a walbro...its just 90$...
Old Mar 18, 2008 | 02:56 AM
mitdrx's Avatar
The money was never the issue. If a IX fuel pump will do the job it offers less noise and lower pressure and maybe some unsubstantiated gas savings.
Old Mar 18, 2008 | 03:17 AM
ApacheFixer's Avatar
id have to say go with a walbro, but if you plan on not modding any more then a 9 pump would be sufficient
Old Mar 18, 2008 | 03:18 AM
mitdrx's Avatar
Thats why i was asking. I will maybe be looking at an intercooler but thats it. More into suspension mods....
Old Mar 18, 2008 | 03:19 AM
krazirob's Avatar
walbro man just get it. you can adjust your maps to save fuel during cruising and still be good. noise isnt a problem at all and incase you go further at least you got the FP.........just me though
Old Mar 18, 2008 | 03:55 AM
Kellendros08's Avatar
If you're looking to buy a IX fuel pump I just upgraded to a Walbro and my old one is just sitting around.
PM me and make an offer.
Old Mar 18, 2008 | 04:15 AM
1d10t's Avatar
LOL! Walbro @ higher pressure! Swapping a pump will not magically make your fuel pressure rise, unless your regulator is shot! LOLOLOL
Old Mar 18, 2008 | 04:47 AM
mitdrx's Avatar
If you look at the test there is a slight rise in pressure even past the fpr....
Old Mar 18, 2008 | 05:22 AM
Chemwarrior's Avatar
It is already been mentioned you can retune yourself to compensate for better miles per gallon and still have that peace of mind that you still have a fuel pump that will handle further modifications if you choose to do so.
Old Mar 18, 2008 | 05:26 AM
deanner's Avatar
I'm running a walbro, fuel mileage won't change, pressures are based on pressure regulator! My 9 fuel pump has 4k on it pm with offer!
Old Mar 18, 2008 | 06:32 AM
sparky's Avatar
At your mod level, the IX pump should be good. You could later add a KenneBell Boost-a-Pump by which you could increase voltage to your pump at W.O.T. A fuel pressure gauge and an AFR monitor will help you keep tabs on pump output. Myself, I just installed a Walbro.
