Taillight out...not the bulbs. Anyone know whatsup?
My driver's side taillight is out. The lights turn on when I brake, turn signal works, but it just wont light up normally.
I changed out all the bulbs with an extra set of tails i had and tried the passenger taillight as well but no luck. I'm not too familiar with electrical stuff but is there some blown fuse or something?
Thanks.
Thanks.
parking lights are when you turn the knob just once, so that the head lights aren't on...but you have the rear parking lights and front parking lights on...just the two top corner amber lights in front...and 4 red in rear.
not sure if the Evo is the same but when i had my supra it a a relay box about 1ft or so from the bulb fitment that needed to be replaced. it had the same prob. i replaced the relay box and it solved the prob.
I had the same problem when I shorted out a fuse when I installed my boost gauge the first time. I believe the fuse you need to replace is in the cabin fusebox. Check the manual for which one. May be interior gauge illumination, but not positive.
RSL4Evr
16
Oct 19, 2011 11:58 AM
CulebraLancer
Aug 28, 2004 03:22 PM
