UGH! Another Steering Clunk
Old Mar 26, 2008 | 10:12 PM
JKD's Avatar
JKD
Hey guys, I did a search and found similar problems other people have experienced. However, I couldn't find any that completely relates to the issue I am having right now.
Today, I got outside and swapped my summer wheels out. I have been riding on the stock Enkei wheels with 245/45/17 Toyo Proxies 4 tires. I swapped this set out for my summer wheels which are Volk TE37's with 245/40/18 Falken Azenis RT615 tires.
Now for the problem. When I swapped the wheels over, it seems I've developed a clunk or pop noise in the steering. At low speeds if I flick the steering wheel a little left or a little right I get this noise. This is only at slower speeds though. What I'm wanting to know is why it does this with the 18" wheels and not the stock 17" wheels. The car has Muellerized' JIC Magic coilovers on it, if that helps any.
I want to know how to fix this and why it only does it with the larger 18inch wheels on the car.
Thanks in advance guys!
Old Mar 27, 2008 | 05:09 AM
EvoDom's Avatar
my car does somthing similiar!...but i have 18 inch roto tourques on it all year round. and mine started doing it like a month after i got my clutch done!
idk what it is...need help!
Old Mar 27, 2008 | 07:47 AM
JKD's Avatar
JKD
Anyone have any idea?
Old Mar 27, 2008 | 07:49 AM
sleepyS14's Avatar
id say check your sway bar links / bushings. possibly worn out. (aka stabilizer bar bushings or the links themselves)
Old Mar 27, 2008 | 07:50 AM
slow_evo's Avatar
I think it's a little bushing that goes in the firewall that helps hold the steering arm. Mine does it every once in awhile and I'm on stock wheels.
Old Mar 27, 2008 | 08:12 AM
JKD's Avatar
JKD
Thanks guys. I'm going to look into it a little more today and see what I can find out. Anything else I need to look out for?
Old Mar 27, 2008 | 09:08 AM
Shadowpriest's Avatar
Mine started does this exact thing this winter. As I'm pulling up to a stop or taking off, or when I've just come to a stop if I turn the steering wheel left or right slightly I get a clunk or pop sound. I did an initial check of my sway bar end links and they look fine. The steering isn't loose or anything either. I had assumed the bushing on the steering rack was making the noise and it wasn't a big deal. Anyone have more detail?
Old Mar 27, 2008 | 09:53 AM
JKD's Avatar
JKD
I got out and checked the torque on my lugs and there fine. I took it for a test drive and it seemed to not be doing it as bad today. I don't know why, but I'm not complaining.
Since there are so many people with similar problems, I'd figure someone would have found a total solution by now. Hmmm
Old Sep 3, 2009 | 08:12 PM
spyghost's Avatar
isn't this the steering shaft spline which is located on the intermmediate shaft between the two u joints?
it it were the culprit, this was originally designed as a sliding shaft during frontal collisions wherein the column slides instead of collapses upon impact, hoping to reduce body injury to the driver.
Old Sep 5, 2009 | 11:26 AM
barneyb's Avatar
Remove the coffee cup and empty propane tank from the trunk.
Old Sep 8, 2009 | 06:26 PM
spyghost's Avatar
i got this sound actually
http://s264.photobucket.com/albums/i...t=Video004.flv
Old Sep 1, 2017 | 07:25 PM
4G63MR708's Avatar
Sorry to bring this up
So I basically sign up just to ask you this question!!!! Same
Thing happen to me after I did my clutch I'm having a clunking noise everytime
I steer slight to left and at a low speed???????
ctrenks
71
Oct 7, 2025 02:19 PM
lancerrally45
Nov 19, 2019 08:51 AM
Igor Nikolic
Nov 6, 2017 06:31 PM
BluEvo62
Jul 12, 2016 07:05 PM
jdogstoll23
May 9, 2016 09:34 AM
