Big Turbo Up Grade Help
Old Mar 27, 2008 | 05:58 PM
jdm_evo8's Avatar
hi
i trying to upgrade my car to a big turbo kit (HTA35R Turbo Kit ) what kind of stuff will i need to buy to be able to put that power down with breaking anything. What kind of Clutch will the power, will i need to up grade the internals of the motor and stuff like that and also will a Apexi power fc be ok to run on the car or should i upgrade to a different stand alone.
thanks
Old Mar 27, 2008 | 06:01 PM
grillpt's Avatar
The SEARCH button is the first only thing you'll need.
Old Mar 27, 2008 | 06:11 PM
zeus1's Avatar
try contacting buschur, ams or ets.. i would suspect all could guide you correctly
Old Mar 27, 2008 | 06:17 PM
philevo's Avatar
ask the company that you're buying the kit from or ask the installer. I say exedy carbon clutch
Old Mar 27, 2008 | 07:55 PM
ekizenbe's Avatar
contact any reputable company on here, they will give you a full roadmap to follow
Old Mar 30, 2008 | 02:29 AM
SpeeDeviL's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=313778
Old Mar 30, 2008 | 02:48 AM
Indy Evo's Avatar
contact U2SLO, Pete will return your PM and point you in the right direction that is safe and works. He has more dd miles on the Hta than anybody.
Old Mar 30, 2008 | 03:01 AM
Johnboy1065's Avatar
if you want to run the 35r to the max You will need to fully forge the bottom end. you will need at least an exedy twin, but more than likely a triple plate clutch. your stock intercooler will also not be efficient at those power levels and neither will your camshafts. I'd go with at the very least hks 280's BUT jun272's gsc2's or bf272's would be best but then you'd have to upgrade the valvetrain. you will need at least 1000cc injectors IMO to run safe duty cycles,1000cc's sometimes arent even enough to max it out. also you will need 2 walbro fuel pumps. IMO you need a standalone. but a lot of power has been made using just the stock ECU. But the problem is the stock ECU is limited as far as how big of injectors it can run. so that is a major limit when you want to push this turbo to the max. also you'd prolly run into ignition issues and for that I'd get at least the HKS DLI II. so....yeah at least what all I've listed here if your plan on maxing the turbo out. (all of these are just my opinions)
BUT if your not wanting to max it out and just want some nice power. get cams, walbro 255lph fuel pump. 850cc injectors, cams, intercooler...no need for HKS DLI II or Forged bottom end, BUT I'd still go with at leas a exedy twin disc as far as the clutch goes
these are some of the basics I reckon
Old Mar 30, 2008 | 05:33 PM
PureDsm's Avatar
i would say contact a peformance company....like sbr and buschur,,,
as far as clutch goes i would say exedy stage 4 but not the carbon to much $ involved
Old Mar 30, 2008 | 08:09 PM
EvolNinja's Avatar
Email Jarrod at Buschur. He'll return your questions promptly. Not that others will not return your email but it all depends on where you live. I would love to go to Buschur but I'm closer to AMS so I'll probably go to AMS during their Grand Opening this May 18. Looking to get at lease above 300whp for my setup.
kingRob757
Feb 27, 2016 01:57 PM
brakeboost980
Jan 16, 2012 03:52 AM
suprPHREAK
Nov 6, 2010 01:20 PM
limey
53
Jul 25, 2004 10:06 AM
cdyancey
17
Dec 18, 2003 04:13 PM
