evo 8 2003 , wiring help
Old Apr 4, 2008 | 05:16 PM
dragers's Avatar
Hi All
I have an evo 8 with 1200cc injectors, sudenly cyl #4 injector lost 12 v positive signal, I fixed the problem using 12V + from #1 injector,
does anyone know how to fix this properly, it doesnt feel right what I did.
thanks in advance for the asistance.
Old Apr 4, 2008 | 06:18 PM
awdwannabe's Avatar
It just sounds like you had an open wire to injector 4 for it to cut out like that. I'd imagine the injectors are wired in a parallel circuit so if one goes out they all don't, but I don't have a wiring schematic in front of me.
But the way you have it now, from what I'm reading it sounds like you spliced the + signal wire from injector one, to power injector 4.. if that's the case thats probably quite a bit more amperage going through that wire than what it was designed for, and may crap out as well.
If I had access to ALL DATA or Shop Key, I'd look it up for you but I won't have access till monday. But from what it sounds like, the #4 injector signal wire basically took a dump, and needs replacement.
Old Apr 5, 2008 | 12:54 AM
dragers's Avatar
thanks for your interest, from the positive wire that goes to inj #1 I made a Y one to inj 1 and the other to inj 4, so now both have power and work,
but I feel this fix did not set things to its original state, if you can help me with this thanks a million.
Old Apr 7, 2008 | 07:12 PM
awdwannabe's Avatar
What year Evo 8 do you have? Just wondering because I looked today at the wiring diagram at school and the positive wire colors change through the years.. there's also a test you can do, I'll try to print it out tomorrow and give you some instructions on how to test that circuit.
mrhussain
Nov 7, 2016 05:28 AM
daveheit
Jul 21, 2016 01:14 AM
JohnBradley
Jan 29, 2014 03:49 PM
sound77
Feb 3, 2013 01:42 PM
CWiLL
Oct 2, 2011 05:10 AM
