Rev limiter question
Old Apr 4, 2008 | 09:30 PM
gunhaha's Avatar
Does the rev limiter work when the car is in neutral?
I tried to bild boost while the car is stationary and in neutral and the rpm went up to 7000. I thought it would be pegged around 5000 rpm.
Thanks
Old Apr 4, 2008 | 09:36 PM
Lonnie@LMS's Avatar
Did you have the clutch pedal pushed down?
Old Apr 4, 2008 | 09:37 PM
evo8426's Avatar
you have to be in 1st gear
Old Apr 4, 2008 | 09:42 PM
Lonnie@LMS's Avatar
^Are you sure? I can't think of any sensors on the evo that tell the computer when the car is in gear. I think it has to do with whether the car has the clutch pushed in or not. There is a clutch pedal sensor for when its pushed down and then one for when its released and I believe that is what determines when the lower rev limit is engaged.
Old Apr 4, 2008 | 09:45 PM
Lancerguy'03's Avatar
you have to comepletey stoped....and it should hit 5000rpm....unless someone changed it with a reflash...if i rember right you dont need to clutch pushed in or be in 1st gear....just stoped.
Old Apr 4, 2008 | 09:48 PM
Lonnie@LMS's Avatar
He stated that the car was stationary. At least thats what he said.
Old Apr 4, 2008 | 09:56 PM
Burklow's Avatar
I'm 99% sure there is a sensor to detect if it is in 1st gear. Don't know where it is exactly though. Much like how other cars have sensors in the tranny to detect when it is in top gear in order to establish a speed limiter. eg. Nissan 240sx. The way they eliminate speed limiters with ease is by placing a switch on the cable that connects to the tranny for gear detection.
For 2-step to work:
- Stationary
- Clutch 100% pushed in
- First gear preloaded
Old Apr 4, 2008 | 10:16 PM
gunhaha's Avatar
The car is on up on the rhino ramp and I was testing for leak in the LICP I just put in. The car is in neutral and clutch pedal is NOT pushed in when I get the 7000 rpm surprise. I bought the car new last year and no reflash.
I guess either you have the clutch in and in 1st or at least have the clutch in to activate the 2 step rev limiter.
Thanks
Old Apr 4, 2008 | 10:55 PM
importjake00's Avatar
So when your driving you can only rev up to 5000 rpms and thats it? then you must shift? i didnt know this..
Old Apr 5, 2008 | 12:06 AM
hanahawaiian's Avatar
that how we launch evo in drag.. fully stop.. put 1st gear in and clutch stay on and press gas and it will rev to 5000 or 5500 depend on reflash ecu and let go clutch and stay on gas that how u launch
Old Apr 5, 2008 | 01:21 AM
I get that, but after first gear, when your shifting to 2nd 3rd and 4th and 5th and in some cases 6, does it still only rev till 5000 or 5500? or is it just in first or what?
Old Apr 5, 2008 | 01:23 AM
Billy@EnglishRacing's Avatar
not that is just a stationary rev limit, the moving rev limit is much higher
also for the 2 step to work you much be at wot
Old Apr 5, 2008 | 01:25 AM
okay thank you, that is what i was hoping to here. your always to my questions rescue
Old Apr 5, 2008 | 01:26 AM
Originally Posted by importjake00
okay thank you, that is what i was hoping to here. your always to my questions rescure
im here to help!
jdbigz
Apr 10, 2015 04:23 AM
besk
Apr 16, 2014 05:51 PM
2012_Evo_X_GSR
Feb 25, 2013 12:01 PM
ed_GST
Lancer Engine Management / Tuning Forums
Sep 16, 2009 10:03 PM
gvillevo
Aug 21, 2008 06:33 AM
