NEED HELP troubleshooting
Old Apr 15, 2008 | 07:29 AM
Redbud23's Avatar
Veteran: Marine Corp
I first had a flutter and thought it was the blow off valve, but I changed it and it wasn't the blow as far as I can see or hear. The one I have on the car is a Metal evo ix BOV. Then it went from a flutter to an incredibly loud whirring or vacuum cleaner noise. This noise has never been present before and I have had the current filter on there since Buschurs put their stages 1-3 on in August of last year. I changed the BOV yesterday and still makes the same type of noise. Is it a possible vacuum leak or cut intercooler pipe or a loose clamp? I checked all the clamps still tight. I checked as much as I could as far as the hoses and vacuum lines. Does anyone have ideas this noise is a little annoying? Thanks for all your guys HELP and again thanks to ATLANTIC MOTORSPORTS
Old Apr 15, 2008 | 07:32 AM
TeStUdO's Avatar
A loud whistling or whirring sign is usually a sign of a boost leak. Check all your vacuum lines and do a boost leak test.
Old Apr 15, 2008 | 07:39 AM
Redbud23's Avatar
Ok I'll try that tonight. Is that in the how to section? Or is it something I keep missing. I looked for it last just to make sure I did it correctly but couldn't find it. Thanks for your help!!!!
Old Apr 15, 2008 | 08:58 AM
Redbud23's Avatar
bump
CN9Adaiski
11
Jan 9, 2014 08:41 AM
Clipse3GT
18
Dec 16, 2009 02:48 PM
dpacific
10
Nov 5, 2008 09:16 AM
phabaznbro
May 30, 2008 06:20 PM
rjsdxm
19
Aug 7, 2007 02:01 PM
