What should i do next...?
Old Apr 17, 2008 | 09:37 PM
BlackonBlack2's Avatar
Current performance mods are as follows...
K&N filter
Greddy Ti
megan test pipe
buschur racing downpipe
hallman boost controller
ams licp piping
walbro fuel pump
Zeitronix Wideband (not working) ( still not working and buyer refuses to admit that the unit was broke when sold) new one on the way...!!! yeye
untuned never dynoed... which is the next thing i'm doing is getting it tuned but afterwards
want to stay with stock turbo but built at least a 400 whp car... prefer to stay away from meth.. and alcohol
open to suggestions
cams? pistons? rods? or just screw wasting all that money and go for a bigger turbo? just don't want the turbo lag to be bad... want it to spool up as quick as possible... around stock... but which is impossible because bigger is always going to mean more turbo lag... unless a stroker kit...
I rather have a better motor that can handle the power then just add a bigger turbo and the motor not handle it...
and the car is more for autox... then drag just want a well rounded 400whp car
Old Apr 17, 2008 | 09:40 PM
idriveanevo's Avatar
cams
Old Apr 17, 2008 | 09:43 PM
Originally Posted by idriveanevo
cams
280's? with valve and spring's
Old Apr 17, 2008 | 09:48 PM
tim85851's Avatar
cams for sure!!! then go for the FP green!!! aka 20glt
Old Apr 17, 2008 | 09:49 PM
72Tornado's Avatar
400WHP on 93 oct. and stock turbo is going to be very difficult indeed. Not a common accomplishment.
You don't need 400WHP for an autox car anyway. Put some money into a high-quality set of coilovers with good adjustability and a set of lightwheel wheels with R-comps.
Old Apr 17, 2008 | 10:02 PM
Mistaken's Avatar
cams!
Old Apr 17, 2008 | 10:07 PM
porsherules911's Avatar
cams will definitely give u some more power
staatz's Avatar
hit the blow off valve.
Old Apr 17, 2008 | 10:09 PM
FLOW1's Avatar
BOV, Cams, FMIC, Bigger Turbo. Some ideas.
Old Apr 17, 2008 | 10:11 PM
have a iX bov... still change it out?
Old Apr 17, 2008 | 10:15 PM
EvolNinja's Avatar
Get it tuned.... 4 Wheel Slide is cheap but great way to learn to tune your own car at the same time.
Old Apr 17, 2008 | 10:16 PM
Tvwj's Avatar
400 on 93 oct is going to be hard to get too. Get cams, uicp, fmic, and get a tune that should help you as a dd car. Get an 20g or and IX turbo if you wanna hit aleast 400.
Old Apr 17, 2008 | 10:17 PM
staatz's Avatar
I meant ..hit it..VRMMMM PSH..lol but as far as mods..I'd do cams.
Old Apr 17, 2008 | 11:07 PM
Corey's Avatar
02 housing
ported exahust mani
bigger cams
bigger fmic
stock 9 turbo or FP green
400whp on 93oct is gonna be kinda tough, but with the right mod combo and a stock 9 turbo you could see close to 400 I would think.
Old Apr 17, 2008 | 11:43 PM
Johnboy1065's Avatar
cams
ported and jet hot coated exhaust manifold and hotside.
02 housing.
I guess those are pretty much the options if you want to stay away from alky/meth
