o2 housing question
Old Apr 25, 2008 | 10:16 PM
EvoHung's Avatar
It helps if you remove the o2 housing and the hotside in one piece. After you have those out of the car you can remove the o2 housing from the hotside easier. This is my daily driven car too and I did this at work. No I don't work at an auto shop, I work at a nail shop, finger nails! Use a bunch of those open end wrenches, you can do it.
Old Apr 26, 2008 | 04:24 AM
evo150's Avatar
Originally Posted by EvoJoeIX
i gave up on it....
i couldnt get that last nut off the stud, its the one that you only have a few inches on room to work with because the o2 housing kinda goes over top of it. its hard to do a time consuming project on your daily drivier, if i had another car, it would get finished..... but i need my car for work purposes
ill pay someone to put it in when i go green, that way it really shouldnt be any extra labor charge
leave the hotside and o2 housing bolted together. after you take the bolts off holding the turbo heatshield on, take off the v-clamp that connects the compressor and hotside. once you have the hotside and compressor seperated pull the hotside out with the o2 housing still attached.
Old Apr 26, 2008 | 09:31 AM
EvoJoeIX's Avatar
i could not get that clamp off turbo....
im not sure what angle everyones is at, but mine has the 10mm bolt facing the engine block, so its a really weird angle and i just couldnt get to it with any of my tools
evoviiihan
10
Oct 22, 2016 10:00 PM
[p]dOG.
Oct 13, 2016 11:13 AM
Danny23
Nov 25, 2006 05:49 PM
badhabit90
28
Aug 9, 2005 09:08 AM
