Death Whine strikes again!
Old May 7, 2008 | 10:57 AM
jpetro10's Avatar
Death Whine strikes again! update on pg2
Whats up fellas, well it happened to me this morning. I have a 2006 Evo IX RS. I drove from Wa to Tucson AZ about 2 weeks ago. I relocated down here. So i was driving to work and I passed a car just left it in 4th, didnt boost much at all, i got around the lady then out of nowhere a LOUD whine starts howling from the front of my car ! I always wondered if i would beable to spot this "DEATH WHINE" if it happened to me, well...theres no mistaking it!
So my question to you guys is, do you think i have ANY chance of getting this covered by a dealer? I did the 30k check up, BUT two things. I did the tranny on my own with redlind lightweight shockproof @ about 34k, THEN i had the dealership i used to work at do the TC and Diff with mitsu oem fluid at about 37k. I do have a reciept for the TC and diff, but not for the tranny or anything else the 30k says to do becuase i did the rest on my own. I would have done the tc and diff on my own to but i was just pressed for time, i guess its a good thing now, lol.
Do you think the miles being over 30k will screw me? Also, i have mods, BUT nothing directly effecting the tc, so im hoping this will save me. I know its a long shot, but i just want to see if you guys have any advice or suggestions.
Old May 7, 2008 | 11:45 AM
bbyevo8u's Avatar
what mods and how many miles?
Old May 7, 2008 | 11:50 AM
jpetro10's Avatar
as of right now i have about 42k and i just listed the mods in my sig.
Old May 7, 2008 | 12:01 PM
newbieEVO8's Avatar
With your mods I doubt you are still covered.
Sorry to hear about your TC, time for an upgrade.
Old May 7, 2008 | 12:06 PM
porsherules911's Avatar
if its your tc going out, wouldn't you hear the whine from the rear of the car and not the front? If its the front whining then wouldn't that be tranny related?
Old May 7, 2008 | 12:10 PM
reggiesd's Avatar
^^^nope that would be the rear differential..transfercase is right by the tranny
Old May 7, 2008 | 12:11 PM
Oki Panoki's Avatar
wow, how does this all of a sudden just come out of nowhere. i always thought you could hear it coming on?? if not that kinda makes me cringe a bit.
can anyone explain how after doing like one hard pull the tc could go bad that quickly i dont really understand how it works
Evoryder's Avatar
sound clip please...search youtube for death whine evo and if it sounds like taht then you should plan to replace the TC.
Old May 7, 2008 | 12:12 PM
Evoryder's Avatar
Mine was all of a sudden, but progressively got louder and louder. It starts in certain gears...at a certain speed.
Old May 7, 2008 | 12:14 PM
Redline-Z's Avatar
Veteran: Air Force
Man that sucks if it is the TC but I really think it wouldn't just go all at once with just a 4th gear pull. I would think this would be a progressive failure that gets worse with time. Just get it looked at. GL.
Old May 7, 2008 | 12:20 PM
jpetro10's Avatar
It wasnt one hard pull that did it. Im sure it was from the previous owner doing launches and what not, and then i wasnt completely nursing it everytime i drove it. I mean with 42k i knew it would happen sooner or later, i was just kinda hoping it would be later, lol.
Ill try and get a sound clip, but i youtubed a few and its identical to the ones on their. It get progressively louder with SPEED not with rpms. but its wierd cuz it almost sounds like its coming from the tranny side?Could it be the tranny making a noise like that? Ill just have to get it in the air and try and identify it.
Old May 7, 2008 | 12:22 PM
EvoHung's Avatar
Take off the meth kit, put stock cat back on, and get a stock factory ROM loaded into ecu, then take it back to the dealership. Do you have extended warranty? You should really try to get it fixed under warranty first since the worst they can do is void your warranty and tell you no. Sounds like your tc must've had a leak or not the right diaqueen differential oil. Yes, the dealership are known to put the wrong oil into your tc. If all else fails, give Shep or TRE a call.
Old May 7, 2008 | 12:26 PM
EvoHung's Avatar
I just re-read your post. It could be your tranny too. Shep recommends redline mt90 transmission oil.
Old May 7, 2008 | 12:46 PM
jpetro10's Avatar
i hope this isnt it, i changed it almost 10k ago with the lightweight shockproof. Should i change the tranny back to oem fluid before i take it in?
Old May 7, 2008 | 01:24 PM
o ok thanks now i know
