this guy needs help fast...
Old May 7, 2008 | 04:36 PM
ch53avitech's Avatar
I unplugged the battery from my car for a few minutes. I connect the terminals back up the go to start the car and it will idle for a second then it will just die. I can give it gas and it won't shut off. I held the gas in for 20 minutes but the car still dies when I let go of the gas. Any ideas...
Old May 7, 2008 | 04:37 PM
bcollinstex's Avatar
Give it a few. It will return to normal. I often forget about this when disconnecting power.
Old May 7, 2008 | 04:40 PM
But the car won't idle, it just dies when I start it.
Old May 7, 2008 | 04:42 PM
ak47po's Avatar
Why did you disconect the battery,did you change something?
Old May 7, 2008 | 04:43 PM
IEXCELR8's Avatar
Keep it running with your foot till it gets warmed up (maybe this will help). Did you check to make sure the ECUflash tune is correct?
Old May 7, 2008 | 04:46 PM
I was reseting the Check Engine Soon light.
Old May 7, 2008 | 04:47 PM
IEXCELR8's Avatar
Why was that on? Did you pull any code?
How do I check that. I didn't think disconnecting the battery will reset the ECU flash.
Old May 7, 2008 | 04:48 PM
holler mcdollar's Avatar
^why are you getting a CEL? your sig says you have a test pipe w/ O2 fix. is it something else?
I pulled a P0300.
Old May 7, 2008 | 04:50 PM
EvoHung's Avatar
I have heard of people saying that if you disconnect your battery for a few minutes it can mess with your flash.
Old May 7, 2008 | 04:53 PM
chrisevo8's Avatar
i disconnect mine all the time and its fine. maybe you shorted something......check your fuses.
Ok, then. What were you doing? Just wondering before I post a bunch of possibles for the problem you are having.
Old May 7, 2008 | 04:54 PM
EvolNinja's Avatar
It's true that by removing the negative terminal for a few minutes and put it back on will reset the CEL light but not for good depends on what's wrong with it in the first place that trigger the CEL light. I'd say take it to AutoZone and have them pull the code for you for FREE! Good luck
Old May 7, 2008 | 04:55 PM
hellcat's Avatar
I agree with the poster that said check your fuses.
