Need help! - Installed Gauges - Where do I wire lights?
Well I installed a triple A pillar gauge pod system last night:
Oil pressure w/ electric sender (0-100psi)
Boost/Vacuum w/ hose system
Autometer DPSS Shift Light/tach combo
The boost gauge and oil pressure gauge have wires in the back for back lights and I don't know a good easy place to wire it in so they light up when I turn my parking lights on. Right now they don't have the light hooked up so I cant really see them at night.
Also, on a MR-9 what should my stock boost be hitting as I spool up say between 3-6K rpm at Wide open throttle? Its hard to stare at because I don't want to crash. I think it was hitting about 19 or so yesterday - is this right for stock? My mods are in the signature below.
If anyone can tell me an easy place to hook those lights I would be forever in your debt!
did you put the gauges in the stock 3 pod? just swaped gauges? whitch gauges did you put in? stock boost on a 9 is 20 and a half! the higher the gear the more you will boost so you wont hit 20psi in 1st or 2nd gear max boost should be in 4,5,6th gear! anyway you should def be boost more then stock with your mods maybe boost leak or the gauge might be off.....you should be tuned with those mods!!
My gauges are on my a-pillar
I have a LICP, UICP, 3.5" IC, and intake coming (from ets)
I'll have AMS tune it after I install those.
Where is the best place to steal gauge lighting voltage?
I don't think I have a boost leak, it may hit 20.5 but I was watching in low gears (1 2 3)
trinydex
Jun 30, 2014 02:26 AM
llDemonll
Pacific Northwest
11
May 22, 2012 01:35 PM
soule77
Dec 17, 2004 04:55 PM
