Wierd shift light
Old May 20, 2008 | 06:28 PM
Jp7's Avatar
Jp7
Originally Posted by TouringBubble
He sent you the VIII diagram ...
Use this one ... https://www.evolutionm.net/forums/sh...ight=ix+pinout
I see that now....
So do I use pin 45?
I think this is correct it says "rpm".
Has anyone done this before.
That would be the orange plug , green wire with white stripe right?
Old May 21, 2008 | 01:23 AM
spdrcr456's Avatar
ohh wow i thought i would be the same for the IX. learn something new every day.
sorry.
Old May 21, 2008 | 02:27 AM
Jp7's Avatar
Jp7
anyone else have a shift light on a ix? can you shed some light?
Old May 21, 2008 | 02:37 AM
spdrcr456's Avatar
Originally Posted by Jp7
I see that now....
So do I use pin 45?
yes do it. be done with it.
Old May 21, 2008 | 07:53 AM
Jp7's Avatar
Jp7
LOL just wanted to see if anyone had done it successfully before. I don't want to break anything. I will get some scotchlok's to tap the wire in.
I still don't understand why I get the funny readings at 3000+ RPM when I wire it directly to the coil.
Old May 21, 2008 | 09:29 AM
Dr.Sound's Avatar
so close to the coils might be giving you interference.
i have mine tapped at ECU for TPS and RPM and it reads spot on .
good luck man, let us know if that solves it.
Old May 21, 2008 | 10:14 AM
Jp7's Avatar
Jp7
TPS?
Throttle Position Sensor? (that wont work!)
I was going to use pin 45, the green and white one.
Old May 21, 2008 | 10:32 AM
spdrcr456's Avatar
he probably tapped the tps for some other reason than what you need. he said he tapped rpm there too.
Old May 21, 2008 | 04:46 PM
Jp7's Avatar
Jp7
Bingo, worked good - 45 it was (green white little guy)
Seems to be ok now, I'll let you know after I drive around tomorrow.
Old May 21, 2008 | 05:07 PM
Dr.Sound's Avatar
yea, i meant i tapped at ECU for TPS and for RPM.....different wires
but yea, u were getting interference.
sometimes EGT probes read funny because when people run the wires back they route them too close to the coils same principal here.
Old May 21, 2008 | 06:26 PM
spdrcr456's Avatar
Congrats.
Old May 21, 2008 | 07:03 PM
Jp7's Avatar
Jp7
Congrats.
woohoo. it looks so cool at night, i took some pictures, I'll make another thread.
Wish2345
May 1, 2012 06:10 AM
mjesenovec
Oct 13, 2009 03:42 PM
DANMEND
Evo X How Tos / Installations
Aug 5, 2008 05:16 AM
bigric09
Jun 23, 2007 06:54 AM
DCD
19
Feb 22, 2006 11:30 AM
