Bad Cam Sensor
Old May 19, 2008 | 10:13 AM
DESERTEAGLE50's Avatar
Bad Cam Sensor
If your cam sensor goes bad will it cause your car not to run?
Old May 19, 2008 | 10:14 AM
AWD Motorsports's Avatar
that is correct.. it will not start in most cases and if its going bad it will misfire..
Old May 19, 2008 | 10:46 AM
Bad cam sensor
Two weeks ago I replaced my cams, could that somehow cause the sensor to go out?
Old May 19, 2008 | 10:47 AM
BBS's Avatar
BBS
What he said. A lot of cars do start but have bad driveability. Make sure your cam sensor has a good wave pattern.
Old May 19, 2008 | 10:50 AM
TeStUdO's Avatar
Did you re-install it correctly?
Old May 19, 2008 | 10:57 AM
SpeedJunkyz's Avatar
Sometimes it will start, but then turn right off while driving, but its completely shot then it'll just not turn......Easy install though Jester and I did mine right in the middle of the orlando streets lol Thats was fun
Old May 19, 2008 | 11:03 AM
lexat20's Avatar
I have a brand new OEM sensor if you need one. Good luck with your car.
Old May 19, 2008 | 12:20 PM
RyuEvoIX's Avatar
He did not do the install, a local performance shop did. Another problem DesertEagle was having was a sever oil leak from the cam seals by the rear corner of the valve cover. Could the oil leak in that area cause his cam sensor to go bad? The car has less then 18k miles on it.
Old May 20, 2008 | 08:46 AM
Tallen's Avatar
Silver Sponsor
If the cam sensor housing is filled with oil the sensor may not function correctly (seen it happen once). The sensor may be dirty or have metal shavings stuck to it. Or it coulf just be bad. It sounds like a shotty install that was done without new cam seals. Take it back and make them do it right.
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
Old May 20, 2008 | 08:51 AM
Curt@MrLed's Avatar
Former Vendor
As siad above. Pull the 3 screws off of the cover and look and see if th round metal peice is tight. MAke sure its not full of oil either.
Old Jul 24, 2008 | 02:09 AM
KevOVIII's Avatar
Sorry to bring back an old thread. So the fix to the CAS housing filling up with oil is to take off the housing and reinstall it using less sealant (with the valvecover and bearing #6 off)? I just installed some cams and I'm having idle/drivability issues. When I checked the CAS trigger by taking off the 3 bolts, a ton of oil came out.
What idle/drivability problems did you guys experience with the CAS housing full of oil? Will it cause the car to run lean? Mine was running 20-ish AFR and was almost impossible to drive.
Thanks in advance.
Old Feb 8, 2012 | 07:28 AM
utripin's Avatar
is it wrong for oil to be in there?
back from the dead, but I'm seeing oil in the area of the pick up for the cam sensor. is this not right?? I'm having starting problems.
Old Feb 9, 2012 | 09:40 PM
luvboost's Avatar
lol funny you bring this back my car wont turn over. It just cranks then puffs a few times then dies then won't start at all. I was wondering if the cam sensor could be the issue.
Old Jan 16, 2014 | 10:17 PM
hycool's Avatar
I am tracing an oil leak around the exhaust cam sensor and removed the sensor and ground to clean up the leak. I do see that the housing is filled with oil looking from the removed hole of the sensor.
Appreciate advise on whether the inside of the housing is supposed to be filled with oil? Sightly lubricated? Or bone dry?
Old Jan 17, 2014 | 09:52 AM
barneyb's Avatar
Bone dry
