Emissions Please help!
Old May 19, 2008 | 08:26 PM
jus24112's Avatar
Hey guys hope you can give me some insight on what my problem might be... I live in Washington state and I have a 03 8 that wont pass emissions.. I have returned the car back to stock as possible the only thing on the car is the cam gears set to dead 0 on both and HKS 264/272's... but when I try to get it to pass emissions it says that the O2's and the Cat monitors are not ready...
Any suggestions?
Thanks any info would help
Old May 19, 2008 | 08:50 PM
tyre11c0rp's Avatar
emissions requirements are by county in WA.
One easy, although shady, option is to re-register in a county that doesn't require testing. http://www.ecy.wa.gov/programs/air/pdfs/Zip_codes07.pdf
good luck.
Old May 19, 2008 | 09:45 PM
RoadSpike's Avatar
Any suggestions?
Did you flash out the rear o2 sensor check? If you did it will throw that kind of problem. Run a ODBII code scanner on it and see if you come up with any error codes too
Old May 19, 2008 | 09:48 PM
importjake00's Avatar
good luck.
Hey man, what ever works right?
Old May 20, 2008 | 06:06 AM
evosean's Avatar
monitors not completed.... you have to drive the car until it passes all of its self tests. clearing out codes deletes all of the self tests. drive car until all monitors complete, if a monitor fails it will set a code, and you will have to fix it not just clear it
Old May 20, 2008 | 06:18 AM
nothere's Avatar
so you have a cell that you keep erasing. You have a cat, hmmm stock cat? Do you do hpde or ?
Just wonder if the cat has been damaged from overheating .. but I really don't know what to suggest. I was able to pass with 262 cams, an anti fouler and a high flow cat.
Unless, have you been flashing the latest round of thinking on cat cels(?), which isn't quite there yet, the anti fouler is your easiest path. If you have not and you are sure of the reason for failure(as you stated above) and its not something slightly different , whoo, I don't know.
s2kvee
Jun 17, 2016 06:20 AM
jgevox
Dec 19, 2013 11:26 AM
Viegasjuice
Mar 10, 2013 04:43 PM
Blackrain
Sep 25, 2011 08:58 AM
02lancerls
Northeast Region
Nov 16, 2005 10:00 PM
