really rich in higher rpms
My mods are in my sig. I'm peaking at about 22-23 psi.
I bought the car with just a mbc. I'm not sure to what extent that its been tuned. But the speed limiter was removed and the rev limiter was raised to 7600.
I just put my wideband in and I'm running super rich up top. At full throttle the a/f is dropping to low 10s and high 9s.
I'm getting a tune soon. I'm just reading up on different tuners.
I have done some logs and I'm getting 1-2 counts of knock around 3300 rpms.
I'm going to do a boost leak test within the next couple of days.
Do you think I'm running so rich because I'm untuned or I might have some sort of a boost leak. My boost doesn't drop that much to redline. 22-23 peak droping to about 18-19 at redline.
I want to eliminate the possibility of any problems on my end before I get a tune.
18-19psi at redline sounds right on an MBC. The best you can hope for the on the stock turbo is 20-21, using a well-setup EBC or customized stock boost solenoid.
A tune will help
A tune will help
