How Low can ya go? Before you run out of gas (Pics)
Old May 29, 2008 | 01:47 PM
  #31
fimotorsports's Avatar
There is a way to drain the tank, two 10mm bolts on the bottom of the saddle tank
Old May 29, 2008 | 02:08 PM
  #32
zbomb's Avatar
Obscure reference: The Seinfeld episode where Kramer takes a test drive and has to see how far he can get the needle to go past E before running out of gas, AKA the candy lineup episode.
Old May 29, 2008 | 03:06 PM
  #33
EVOSE06's Avatar
Heh heh I remember this episode.
Old May 29, 2008 | 07:47 PM
  #34
Jay644's Avatar
Originally Posted by newimportowner
actually you should have about 2.5 gallons when light goes on and 3.5 to go back off. I routinely get 330-370 miles per tank and have been expirimenting with this also.
I just bought my evo a couple weeks ago and the first time I filled it up was when the gas light came on. Anyways I thought something was wrong cause I filled it with only 11.2 gallons.
On my 2nd tank the light came on, I drove around a bit more, then it went off. This time it filled up with 11.5 gallons, I was so confused. Not anymore though.
Good information to know.
Old May 29, 2008 | 08:27 PM
  #35
krazirob's Avatar
once mine hits E i know at the least i can make it to the nearest shell or BP gas station........i never worry when the light comes on.......its when it gets lower that i start to worry...
i know also that its bad for you pump to start the car on an empty tank as low as that.......
Old May 30, 2008 | 04:41 AM
  #36
PHDoc19's Avatar
Twix is the only candy bar with the cookie crunch
Old May 30, 2008 | 09:23 AM
  #37
92gsxbaltimore's Avatar
I had mine like that before, completely forgot about it. When I filled it up the pump said I had put in 14.1 gallons... :O
Old May 30, 2008 | 09:38 AM
  #38
Turbo Kyle's Avatar
Good to know...I will need to do that when I swith to E85
Old May 30, 2008 | 10:40 AM
  #39
Evo9"Miss Rose"'s Avatar
hahaha sweet pic..ive too done that as well but i took it to the limits as in running out of gas and pulling off to the side, just had 2 more blocks to hit the gas station but it sure died on me..i took it 40miles after the light turned on.(freeeway) just to give ya guys heads up too see how far you can go when the lights on. BUt i dont advise to do it hhahhhaha
Old May 30, 2008 | 11:03 AM
  #40
inco9nito99's Avatar
What you should've done is reset the odometer when the light first comes on and then see how far you can go :P.
Old May 30, 2008 | 11:05 AM
  #41
Redline-Z's Avatar
Veteran: Air Force
A couple of reasons this is bad...Water and dirt are heavier than fuel, thats where all the junk is. I never go below 1/4 unless I miss it due to my column pod which almost got me once on the Autobahn Illegal to run out of gas!
I have plans for a SS 1/4in drain valve in the near future
Old May 30, 2008 | 01:12 PM
  #42
ohsobaked's Avatar
thanks for info...
Old May 30, 2008 | 02:11 PM
  #43
EvolNinja's Avatar
Good info. I have always get some gas when the first ligh lit.
Old May 30, 2008 | 02:45 PM
  #44
Redline-Z's Avatar
Veteran: Air Force
<--Looking into this, if their are 10mm bolts then all you have to do is reduce it and put a SS 1/4in ball valve in and your in business I am an Aviation Fuels Specialist and water is a big concern with us. We draw off water all the time from condensation and it builds up pretty quick. I would like to be able to do this on the Evo just to be sure it's free of water hence the drain valve especially after sitting for a couple days.
Old May 30, 2008 | 02:57 PM
  #45
Turbo Kyle's Avatar
Make em' and sell em' Ill take 2
