How Low can ya go? Before you run out of gas (Pics)
Old Jun 7, 2008 | 08:38 AM
  #61
Iridesi's Avatar
Nice, good job getting that fuel needle that low, next thing to accomplish.. Getting the needle so low that it is just enough to reach just outside the gas station. :P i would never take my car that low, I dont have brass ***** haha
Old Jun 7, 2008 | 01:40 PM
  #62
EWWEvo's Avatar
it must have been painful driving under the speed limit to see how far you could go
Old Jun 8, 2008 | 06:38 AM
  #63
barneyb's Avatar
Originally Posted by dudical26
People always say running low kills your fuel pump but I have not had that experience. I almost always run around with my car below 1/8 tank and have on many many occasions had it go half way into the letter "E" ---- this is about as low as you can go before you run out. Once you get this low you can fill up with 14.2 gallons or so, neat trick for a 14 gallon tank.
If you think thats bad then I don't know what you'll make of my friend mike. I have never been in his car when the low level light was not on. And this doesn't mean he drivers slow whenever the light is on, he drives full throttle pretty much all the time and has never killed a fuel pump. I think that whole dirt and water and the bottom of the tank thing is a bit of a myth.
Looking at the way the pump is constructed and how it works, I don't see what difference there is as to whether the tank is full or nearly empty. The pump is cooled by fuel passing through it and the work it has to do is about the same either way.
Also, since people are prone to running out of gas, I can't imagine the builders using a pump that fries every time the tank goes empty.
Old Jun 8, 2008 | 09:26 AM
  #64
EVORaab's Avatar
I always fill up above 1/4 tank
Old Jun 8, 2008 | 02:31 PM
  #65
XK120's Avatar
Just got 320 out of a tank, and the light had just come on as I came into the gas station! WOOT
Old Jun 10, 2008 | 11:45 AM
  #66
BosanskaTrava's Avatar
WHAT!!!!!... i got up to 250miles a tank and the car died on me on the hi-way... first started cutting the fuel off so i had to floor it to keep it running.. but then goneee... 250miles/14gallons
Old Jun 10, 2008 | 12:32 PM
  #67
SoundBoy4's Avatar
I read that there is gunk that accumulates at the bottom of the fuel tank over time and that it's best never to let your car run that low on gas and suck that stuff up.
Old Jun 10, 2008 | 01:56 PM
  #68
MitsuJDM's Avatar
I've acually completly ran out of gas before. I was about 3 houses away from my own house. The road goes slightly uphill so I couldn't push it home
I think I may have already posted in this thread, but I get between 210-230 miles per tank. Aren't the 04+ tanks bigger then the 03's?
Old Jun 16, 2008 | 08:24 AM
  #69
iziegsx's Avatar
Hmm i want to know more.
Old Jun 16, 2008 | 08:39 AM
  #70
jmartinez1170's Avatar
back in the day i tested this out on pump gas on the highway i got 72miles from where i was from to the gas station by my house. I did it on the highway do 65mph the whole time. Mods at the time everybolt on plus cams, AEM, 880's.
Old Jun 16, 2008 | 02:18 PM
  #71
selp's Avatar
the light comes on at about 3.5 gallons left in the tank.
so, if you are getting 20+ miles to the gallon, do the math.
Old Jun 16, 2008 | 02:24 PM
  #72
400AtTheWheelz's Avatar
havent gone that low and dont plan on it
Old Jun 16, 2008 | 05:48 PM
  #73
DocCola's Avatar
I've been told its really bad for the fuel system/pump to get that low. But maybe thats only if you do it all the time between fill ups.
Old Jun 16, 2008 | 06:26 PM
  #74
mr_brightside's Avatar
i wouldn't count on our indicator being too accurate. don't get stranded
Old Jun 16, 2008 | 06:55 PM
  #75
19DB794's Avatar
I dont think ive ever let me Evo get that low so far... Probably 1/8th of a tank is the lowest ive gone. Maybe one day...
