Car wont start, ran perfect before being parked for 2 weeks.
Old Jun 2, 2008 | 04:58 PM
camMCLEAN's Avatar
Just got back from vacation, car sat 2 weeks and the battery was dead, just like i expected it to be...
so i call AAA, they come out and jump it and it sounds like its about to fire up but wont. it just keeps cranking over.
car has gas in it, no CEL, and ran flawless before i parked it for the last 14 days.
where would be a good place to start troubleshooting before i have it towed 70 miles to south coast mitsu?
Old Jun 2, 2008 | 05:06 PM
2006gsxr1000's Avatar
Start with the basics. Fuel, fire and air. See if it's getting fuel at the fuel rail, check to make sure the plugs are firing and make sure you don't have anything blocking the air intake. I.E any animals that might have crawled up in there and caused a blockage. Remember start with the basics. You need to make sure your battery is in good shape and not just cranking the car. If the ecm isn't getting the proper voltage and amperage it will not operate correctly. Have the battery checked at your local autozone, pep boys, etc. Good Luck
Old Jun 2, 2008 | 05:17 PM
camMCLEAN's Avatar
yeah, thats what i figured. its just that its an hour away from my house with tools and garage space and so im just trying to get ideas before i have a buddy drive me back down there to see whats up with it. i just dont want to drive down there, then still be stumped and have to drive back again the 2nd time, car less.
i appreciate your help
Old Jun 2, 2008 | 05:26 PM
felickz's Avatar
Pull da plugs
Old Jun 2, 2008 | 07:05 PM
holler mcdollar's Avatar
subcribing hoping you fix it since i'll also be away for a bit soon and this crap might happen to me too...
Old Jun 2, 2008 | 10:29 PM
Redline-Z's Avatar
Veteran: Air Force
Originally Posted by felickz
Pull da plugs
This is what happened to mine, put in nerw plugs and bam fired right up. Sat for 30 days and then wouldn't start. Eventhough when I grounded out the plugs I seen a spark, it was too faint. So the problem took a little while to troubleshoot and I just said it had to be the plugs and it was. Just give it a try
Old Jun 3, 2008 | 03:30 PM
andreww238's Avatar
plugs, crack fuel line to check pressure, check ALL fuses, if all that passes you can usually smell a fried ecu, check Cam angle sensor. sumtitmes the internal parts get loose and back out and crank pos. sensor. my car wouldnt start cuz the timing jumped somehow..
Old Jun 3, 2008 | 03:47 PM
BGR's Avatar
BGR
I don't get it, I mean the car sat only for 2 weeks, not months or years. Why would it give trouble starting for not being fired up for 2 weeks? I see some of you have had the same trouble and it's puzzling. Would this happen to any car? It never happened to me before and I have had cars sitting for over a month and longer when I go to Europe and they fire right up...little hesitant but no major problems. Just curious, is this an Evo thing?
Old Jun 3, 2008 | 04:56 PM
barneyb's Avatar
Was the car parked outside in the rain?
Old Jun 3, 2008 | 09:21 PM
mdinubil's Avatar
It is probably a wiring problem. I had a similar situation and for whatever reason the dealership did tow it since it would not start and found some croded (sp?) wire cleaned it and fired right up. Just a suggestion.....
Old Jun 3, 2008 | 09:41 PM
importjake00's Avatar
Fuses?
Old Jun 3, 2008 | 09:54 PM
tim85851's Avatar
change those plugs!!!
Old Jun 4, 2008 | 12:10 PM
Bom's Evo's Avatar
most of the time its the plugs, since its not the battery.
yukima
Aug 2, 2017 11:26 AM
casper980
Sep 1, 2015 07:47 AM
nytalonTSi
Apr 5, 2011 05:38 PM
slovette
Automotosports - Illinois
12
Mar 11, 2010 07:37 AM
CityKnight
Lancer Troubleshooting
10
Jul 4, 2007 12:22 PM
