Problems-- need help!
Old Jun 7, 2008 | 07:47 PM
  #31
ohthree's Avatar
Originally Posted by _Evo7_
Relay(s) ???
Old Jun 7, 2008 | 07:49 PM
  #32
IEXCELR8's Avatar
Did you try a fuel pump , also the wires could be corroded in the fuse panel.Are you throwing any codes? Put the stock FP back in to see if it is the pump.
Pull the 40amp fuse under the hood, place it back in and see if it starts.
Also check the #8 fuse to see if it blew, it's a 20a fuse. If so the wiring to the o2 sensor is shorting out.
Old Jun 7, 2008 | 10:35 PM
  #33
asilverixmr's Avatar
I had a similar problem before it turn out to be my after market blow off valve came off. Check that or your vacuum hoses.
Old Jun 7, 2008 | 10:58 PM
  #34
ohthree's Avatar
Not throwing any codes, i'll try pulling the fuses like you said, hopefully it's something that simple.
Thanks everyone for the input, any more suggestions are always welcomed.
Old Jun 8, 2008 | 06:59 AM
  #35
Deepseadiver's Avatar
Well... what did you find?
Old Jun 9, 2008 | 05:52 AM
  #36
ohthree's Avatar
I'll let you know tonight! Have been away from the house working all week.
Old Jun 11, 2008 | 11:57 AM
  #37
ohthree's Avatar
Turned out to be engine control fuse. Now the car has trouble idling starting up (have to give it gas to actually get to normal RPMs) which I'm assuming once I have some time to drive around that'll get the alternater all recharged. This didn't affect the tune flash that I have on it does it? Just in case I'm going to reflash the car most likely and see how it goes. Thanks for your help! Saved me a good amount of money.
Old Jun 11, 2008 | 12:04 PM
  #38
_Evo7_'s Avatar
good to hear it was nothing serious. as for the idling, it doesn't sound like it has anything to do with the battery or altenator. the altenator doesn't need charging? it charges the battery?
assuming your tune was lost, the re-flash will probably fix the idle...
Old Jun 11, 2008 | 12:29 PM
  #39
ohthree's Avatar
Yeah whoops. Most likely.
Old Jun 11, 2008 | 12:33 PM
  #40
PVD04's Avatar
You can't lose a tune. Your idle problem may be another issue. Start the car and let it idle up to operating temp. This will allow the ECU to learn its idle fuel trims and may smooth the idle.
Old Aug 11, 2008 | 08:17 AM
  #41
LVIIIR's Avatar
Just wanted to add, this same thing happened to my 06 MR and i thought for sure it was an alternator, turns out it was the ignition coil fuse that has blown...so just make sure to check all your fuses!!!
Old Aug 11, 2008 | 04:56 PM
  #42
Nunzie's Avatar
If this is happening to several cars, what is causing it? Is is a bad ground on the fuel pump?
Old Aug 11, 2008 | 06:17 PM
  #43
EvolNinja's Avatar
The lights and everything in the car were working so it seems the battery has a charge if that is what you meant. Everything turns on as normal, its just when you turn the key all you get is the igniting firing and nothing starting. Alternater then?
Did you have someone try to help you jump start the car? If that doesn't work, I'm guessing it's probably the fuel pump. Yesterday I install my Walbro fuel pump, I remove the power to the pump and start the car so that there isn't pressure on the gas lines, I get the igniting and trying to start but wouldn't start. Good luck
01 Trans-Am WS6
Oct 6, 2012 12:50 AM
SiliconTek
North Texas Evo Club (NTEC)
53
Dec 2, 2011 09:33 AM
Oki Panoki
Jun 29, 2011 02:47 PM
edIT
Jun 15, 2011 01:03 AM
gloom
Dec 19, 2010 12:43 PM
