Noise, Need Help Please!
Old Jun 17, 2008 | 02:21 PM
Hen5000's Avatar
I have it on my stock evo 8 as well. Only got 23k miles on it and occasionally i hear it. It comes and goes i have no idea what it is. I've never noticed it on turns though. Everything in the car feels fine. I don't feel anything shaking or knocking while i shift and drive.
Old Jun 17, 2008 | 04:35 PM
el producto's Avatar
Does it sound like an engine noise or a suspension noise cuz the evo is a noise *****, get used to it as your car gets older.
Old Jun 17, 2008 | 06:08 PM
Akisan2's Avatar
Also consider this as well.
https://www.evolutionm.net/forums/sh...ad.php?t=51431
Old Sep 9, 2008 | 05:35 PM
Celica2EVO's Avatar
I have been having the same sound now. Anyone know what it could be? I know its not a wheel bearing or axle as I have new DSS stage 5 axles with the new hubs on them. It sounds like the rear diff. I am also saying that because if Its louder as you turn (one axle turning faster than the other) the gears on the inside of the diff are going to turn at different speeds.
So if you have had this and fixed it, did it just need new fluid or what did you do to get it fixed?
Thanks
Old Sep 22, 2008 | 05:19 AM
sprx19's Avatar
Check the belt tensioners. I had a timing belt ten. go bad in my wrx and it sounded like a rod knocking at real low rpm and then would go away. It had an oil dampner with a blown seal.
Old Nov 21, 2008 | 02:28 PM
evascst's Avatar
sorry ti bring this back from the dead but i figured id update with the fix for my car,
it was rear differential chatter.
i changed out the fluids and it was all gone
babaz7
Oct 2, 2017 05:22 PM
Hitman_99
Dec 25, 2010 11:02 AM
kidkayos
14
Oct 12, 2010 01:58 PM
Kdash106
20
Feb 2, 2009 01:59 PM
MisterMR
Jan 17, 2006 09:47 AM
