Rostra Cruise Control
Old Jul 2, 2008 | 02:27 PM
EgoBstr's Avatar
Hi Guys -
I installed a Rostra in my car a while back using the how to on this forum. I need some help with two small things. I have everything in place besides the following:
- vss (how to says it is the wire on top of tranny)
- engine speed (how to says it is tapped from ecm behind glovebox)
I cannot find these wires. I would think that I was tapping into the correct ones and the cruise wouldn't work. Can someone tell me in a bit more detail exactly where these wires are (ie, pin location/picture even) and what color they are? Then hopefully my cruise will work.
I have posted this before but didn't receive any help.
Thanks a ton.
Old Jul 3, 2008 | 06:42 AM
EgoBstr's Avatar
There has to be someone on here that can help out with this.
Old Jul 3, 2008 | 07:08 AM
mostH8D's Avatar
if you dont mention buschur or ams in your post you will prolly not get any hits. if you had a vagina that would help too.
to answer your question, sorry i cant help. im interested myself as i want to do this.
Old Jul 3, 2008 | 07:48 AM
Gamble's Avatar
Did it come with instructions or is there a write up on line?
Old Jul 3, 2008 | 12:22 PM
EgoBstr's Avatar
There is a write up online and there are general instructions in the universal kit, but the questions I have are specific. The write up address the the questions, but I cannot find what they reference. There needed to be a bit more detail in it. I even sent the person who did the write up a few pm's but havent heard from him.
Old Jul 3, 2008 | 03:10 PM
MasterNater's Avatar
I don't know if this will be of any help, but EvoMoto has a diagram of the Evo VIII ECU Pins. You can look at it here...
http://evomoto.com/tech_info.php?tPa...1d0ce666fed448
It lists the Vehicle Speed Sensor as pin 86. I think this is one of the wires you were looking for.
I'm not sure about the engine speed sensor. Maybe it's the same as the Tach Signal (or rpm signal) pin 58?
eloylb
Feb 15, 2014 05:38 PM
franc01
Jan 31, 2010 02:47 AM
franc01
Nov 6, 2009 12:19 AM
Fourdoor
Sep 5, 2004 11:11 AM
Evo D
May 28, 2003 09:37 AM
