how do i clean the corrosion off of my stainless exhaust manifold
Old Jul 14, 2008 | 02:42 PM
Davethewave's Avatar
how do i clean the corrosion off of my stainless exhaust manifold? i dont care about the discoloration, i just want to clean the corrosion spots off of it? i read somewhere that you could use alcohol and scotchbrite or something like that? will neverdull work?
Old Jul 14, 2008 | 02:45 PM
boostGotMeLaid's Avatar
+1 i want to get it all cleaned up i have a rnr non coated and its looking a bit nasty??
Old Jul 14, 2008 | 02:48 PM
JJsEvo8's Avatar
Funny you ask, i just spent the weekend cleaning the underside of my car (I know, Im obsessed).
To clean up most of the metal, i used a chrome wheel cleaner, its acidic, so you gotta be careful. I let it sit for 5 to 10 minutes then washed it off thoroughly, ill have to upload some pics, really cleaned up nice
As for the exhaust, its a different type of metal, i dont think its cleanable.
Old Jul 14, 2008 | 02:50 PM
compscibOi's Avatar
Steel wool and then mothers polish.
Old Jul 14, 2008 | 03:50 PM
ball7068's Avatar
Eagle One or Mothers MAG & Aluminum Polish. Put a little bit of the polish on a cloth and rub it, w/ a swirling motion. The polish will turn black. Then wipe it off with a swirling motion. Repeat until it glistens like new.
This also works well for exhaust tips and other metal items. It will put a nice finish on just about any unfinished metal, provided the time and patience.
Old Jul 14, 2008 | 07:06 PM
MRevolutionIX's Avatar
if the chemicals wont work for you try some 0000 steel wool, the real fine stuff. i have used it on a couple SS exhaust systems and worked perfect. wont scratch it and after some polish it will look like new.
Old Jul 15, 2008 | 01:25 AM
Spish's Avatar
I had the same prob with a SS header on my last car, I ended up taking it off and wet sanding from rough to about 1500 grit sandpaper then used mothers to polish at the end, worked wonders!
Old Jul 15, 2008 | 09:06 AM
DRAGHICI's Avatar
this is what I did also but on my factory exhaust tip, plus at the end I used mothers mag cleaner for the final buff, it now looks brand new.
make sure you wet sand, not dry sand when using the sand paper.
Old Jul 15, 2008 | 09:35 AM
JJsEvo8's Avatar
Will this work on the entire exhaust system? Also, how do you stop it from Corroding again? Its very unsightly.
BadAWCpumpEvo
Jul 30, 2017 09:05 PM
snafufx
10
Nov 30, 2013 07:57 AM
Evo9tunerz
Jul 19, 2010 02:15 PM
Keith-PURE Tuning
12
Feb 21, 2009 09:55 AM
