Found out the hard way the undertray does NOT have to be removed to change the oil
Old Jul 20, 2008 | 05:51 PM
ev0srule's Avatar
Man my undertray wont fit over my race fmic, it's too damn big, aftermarket from buschur is too damn expensive to. so plan on that if you upgrade to a larger intercooler....
Old Jul 20, 2008 | 05:53 PM
max2evoix's Avatar
and i thought i was bad
Old Jul 20, 2008 | 06:01 PM
felickz's Avatar
The undertray isnt hard at all to take off? 5 minutes max?
You just have to understand how the plastic "screw" panel clips work. You will spin the screws forever if there is not pressure on the outer clip. So when you are removing them pull on the undertray a bit until you feel the screw "bite"... puting them in, just pinch with your fingers to get the screws in the outermost position and then insert them using the same philosophy.
Faust
76
Nov 6, 2018 06:47 PM
DecepticonsMR
MitsubishiParts.net - WA
Oct 19, 2010 11:00 PM
Blitz
Mar 2, 2010 10:27 PM
Aux.
Feb 13, 2007 08:50 AM
500whp.com
Dec 5, 2005 05:57 PM
