Very bad luck on my way to get my car tuned
Old Jul 22, 2008 | 02:45 PM
teribble's Avatar
What was your dyno numbers? Have you adjusted your clutch? maybe blead the line you could have air in it.
Old Jul 22, 2008 | 04:19 PM
MitsuJDM's Avatar
Originally Posted by Johnboy1065
I did notice something last night though. when I put the car into 1st or reverse and had the clutch IN the car would still barely be pulling itself. anyone know what this may be??? I guess the clutch is not disengaging properly but what could cause this???
I appreciate ya'lls help
Definatly sounds like there is a disengagment issue. Try adjusting the pedal. Could be a throw out bearing issue, since your having issue when trying to disengage or engage the clutch.
Did Buschur notice any issues on the dyno, or have an idea of what it could be? I would have seen if they could have diagnosed the issue and just add it to the tune bill.
Edit: I said "issue" many times
Old Jul 22, 2008 | 06:26 PM
pjb00stin's Avatar
^^^exact same thoughts I was thing.first thing you should do is adjust ur cluth..who installed ur clutch?
Old Jul 22, 2008 | 07:07 PM
RunRunRun's Avatar
Throw out bearing?
Old Jul 22, 2008 | 07:35 PM
Jimp23's Avatar
sorry about your luck. Did you get a clutch extender rod?
Old Jul 23, 2008 | 12:10 AM
Johnboy1065's Avatar
I'll try and adjust the clutch here later today. It's making a HORRIBLE noise though so I'm thinking it has to be the throw out bearing. I really don't think the clutch pedal would be that far out of where it should be to be making these kind of noises. but hell, I wish it would be the clutch pedal, tha'd make life so much easier
Old Jul 30, 2008 | 01:28 AM
I made a post about what is damaged in my clutch
I have pics of it.
Ya'll outta look and see if ya know what might've caused it.
https://www.evolutionm.net/forums/sh...d.php?t=360629
thanks,
John
Old Aug 1, 2008 | 09:33 AM
mullen's Avatar
Man That Sucks Real Bad, Hope Ya Get It Figured Out
Old Aug 1, 2008 | 10:23 AM
skoarpio's Avatar
dyno numbers fool where are they
