How much hp is our stock bottom end good for?
Old Jul 27, 2008 | 12:19 PM
Vibrant's Avatar
Just curious. I am currently at about 340hp on a stock block and turbo. I just have HKS 272 cams, MBC, Buschur TBE, cat delete, Walbro, and a tune on 91. I am wanting to push over the 400hp mark while retaining a good level of reliability.
Old Jul 27, 2008 | 12:56 PM
Bora's Avatar
I've seen 400 on stock but that is right at the point where you need to start pushing out of the stock realm.
Old Jul 27, 2008 | 01:04 PM
EvoJoeIX's Avatar
ive seen cars over 500hp on stock bottom end, just upgraded rod bolts and headstuds
not sure how reliable that is tho, after a while, somethings gonna give
Old Jul 27, 2008 | 01:05 PM
Draven83's Avatar
alot. look at STM's record setting evo. only cams and head studs.
Old Jul 27, 2008 | 01:12 PM
fox2boost's Avatar
depends who you talk to, i say 400 is the most and still reliable. It all depends on how you drive it if you beat the crap out of a stock evo all the time youll blow it up eventually. just my 2 cents
Old Jul 27, 2008 | 01:18 PM
jmelocik's Avatar
I am pretty sure Chris at Mellon tuning has pushed over 520 on the stock bottom end with a HTA35R kit on his Evo. He drives his car on a regular basis and drag races it fairly regulary too. I would have to agree though that the stock rod bolts need to go and head studs should be used if you turn up the boost significantly. Just my .02
Josh
Old Jul 27, 2008 | 04:42 PM
Mellon Racing's Avatar
500+awhp for about 10k miles now I'd guess...I run it hard daily and drag race pretty much weekly. Stock rod bolts but I did do the ARP head studs. I spin it to 8500rpm with the HKS 280 cams and stock springs.
30psi on 93 octane, stock mas, stock ecu, stock block, stock head.
I put c16 in it and tuned it to the same AFR and boost but added 4* of timing and it was showing 565awhp, did a few passes like that a month ago but the clutch was failing and I couldn't get it into 4th very well at all
got a new BR shorty/head/cam on the way now.
Old Jul 27, 2008 | 05:35 PM
xxNosTankxx's Avatar
I dont know if Sean Ivey still has his Evo or not but I know he had a 500whp+ Evo on a stock bottom end
Old Jul 27, 2008 | 05:42 PM
Jim in Tucson's Avatar
Lots of 500whp Evos here. 500whp stock block club If the motor is good for 500 it should hold 400 OK.
Old Jul 27, 2008 | 05:46 PM
SRTRaceR04's Avatar
Still doesn't mean your engine won't grenade with 300whp. There are a million factors out there that can decide whether your bottom end is going to hold "X" amount of power.
Old Jul 27, 2008 | 05:48 PM
ImprezvSE's Avatar
I have about 6k on mine so far and spin it to 8200 very often. No problems so far. Knock on wood!
Old Jul 27, 2008 | 11:02 PM
red evo8's Avatar
i'd vote depending on abuse,miles, and what mods are done around 450-500.
Old Jul 27, 2008 | 11:43 PM
highbredcloud's Avatar
I guess the real question should be...not how much can the stock bottom end handle...but rather for how long?
Old Jul 27, 2008 | 11:51 PM
ninekrevs's Avatar
500-550. although i have seen some above 550 on the stock block.
Old Jul 28, 2008 | 07:20 AM
good points made:
1) some engines blow with stock hp, there are no guarantees
2) just because it makes 500 that doesn't mean it'll last forever at that power
personally I started saving up for a built shorty the day I made 500awhp, just in case.
