Evo 8 weak links, and common problems?
Old Aug 25, 2008 | 07:53 AM
Nasty Evolution's Avatar
As much as we like to think otherwise I'm guessing like every other car on the market the EVO has some factory weak links or parts that like to fail. I'm looking for some insite on what to upgrade or check for, do and dont's.
Example my previous car was an SRT-4, the SRT guys know that the sway bars suck, they like to eat front wheel bearings, and an aftermarket suspension bushing kit is a must even on a stock car.
I've heard the tranny can be a common problem on these as mine is curretly grinding into 4th at anything above 6k with some quicker shifts.
Been told the transfer case is my friend so don't beat it up lol.
Old Aug 25, 2008 | 08:01 AM
ddfelix5494's Avatar
yeah that and obviously the clutch...try changing the tranny fluid im actually about to go get some mt90 to throw in right now
Old Aug 25, 2008 | 08:05 AM
drano7823's Avatar
I would say the biggest weak leak in the Evo is the transfer case, if you plan on going to the track and launching it you can pretty much count on it going out.
Old Aug 25, 2008 | 08:22 AM
Ruff Ryda's Avatar
New owners. lol
Lifters, I don't think they hurt anything but they get on your nerves.
Old Aug 25, 2008 | 08:47 AM
OldschoolEVO's Avatar
that space between the steering wheel and seat usually causes most of the problems, and theres no warranty fix for it either
Old Aug 25, 2008 | 08:52 AM
chu's Avatar
chu
I've heard weak 3rd and 4th gear synchros. Shep usually replaces them with updated ones. Someone correct me!
Old Aug 25, 2008 | 09:05 AM
ranz's Avatar
i would say the transfer case!
Old Aug 25, 2008 | 09:40 AM
evo8nfs's Avatar
the t-case will be fine unless your popping the clutch...... but yes the t-case is very much the weak point on these cars.....
Old Aug 25, 2008 | 10:01 AM
hokiruu's Avatar
OPEN FRONT DIFF.
Many people don't realize that it's the open front diff on earlier VIIIs that causes the transfer case failure, not the transfer case itself. If you are launching or driving an evo hard that has an open front diff, that is most likely the cause for the broken transfer case.
CLUTCH
Designed weak to prevent divetrain damage
FUEL PUMP
There's a good reason even low power VIIIs are using Walbro 255s.
HVAC unit sucks and get stuck. full TSBmust be performed probably out of pocket.
VIII Recaro bolsters prone to breaking
...want more? Cause I can keep on going...
Old Aug 25, 2008 | 10:17 AM
vicbdn's Avatar
hvac unit? how's that get stuck?
Old Aug 25, 2008 | 10:37 AM
hokiruu's Avatar
well the early VIIIs didnt have a cabin filter. the blender door then gets jammed from dust. then it's hard to turn the knobs. then the knobs crack off from being too hard to turn. then you buy a new dash control unit. it's still hard to turn. then you buy a TSB kit to fix it, and have to take out the dash to perform the TSB and fix it for good with a TSB kit.
I went through that whole spiel and got as far as having the TSB kit.
holler mcdollar's Avatar
something not mentioned yet that i suffer from... SQUEAKY SEAT! easy fix but man it is annoying.
Old Aug 25, 2008 | 11:22 AM
Toxin's Avatar
Transfer case, clutch. Launching the car will kill both but it's oh so very worth it.
Old Aug 25, 2008 | 11:46 AM
andreww238's Avatar
im going to say the clutch by far...
Old Aug 25, 2008 | 02:54 PM
chaotichoax's Avatar
search
closed...
07KBPTLS
Aug 28, 2011 06:09 AM
Still_Spinnin
Dec 10, 2010 06:29 AM
bigdaddygnar
May 7, 2007 04:55 AM
securitron81
46
Jun 30, 2005 12:25 PM
