e85 thoughts ?
Old Sep 6, 2008 | 12:36 PM
sdfontanini's Avatar
I'm lookin to go e85 next wkend but worried i'll run into ignition issues with the stock ignition coils. i purchased head studs, 880cc injectors, fuel rail, and a 255 soc filter for my walbro. debating of whether or not i should upgrade my coils or possibly get a hks dli capacitor for this upgrade.
wartalon what psi are u currently running? i've heard guys runnin into issues w their coils when super boosting > 30 psi
Old Sep 6, 2008 | 12:40 PM
SILVERnSLOW's Avatar
I've had no issues. Ran it to as high as 30 psi, but typically run 28. Make sure you get a good tune.
Old Sep 6, 2008 | 12:58 PM
Jim in Tucson's Avatar
Only three things needed to run E85 (1) larger injectors, (2) Walbro 255 fuel pump, and an (3) E85 tune. That's it. Period. And you already have the pump and injectors.
Install. Tune. Done. Enjoy!
Depending on current condition, you might want to include a fresh set of copper plugs gapped at 0.020", or if you'd rather follow Warr, gapped at 0.019".
Old Sep 6, 2008 | 01:38 PM
Warrtalon's Avatar
Where are you hearing these things? You aren't on RMEVO asking, so you're not hearing them there. Jim in Tuscon told you again - same as I said.
You didn't need head studs nor fuel rail, and I don't know what a "255 soc filter" is. You need 880s, fuel pump, and B8RES gapped to .019 (.020 if you can get away with it).
The exact # of psi I'm running doesn't matter. Look at my times. Do you see anyone faster up here? No, and not even close. 2nd fastest is Tobz, and he tunes both of us. He does already have an expensive SparkTech and head studs, but I have stock ignition, stock head bolts, stock FPR, and stock fuel rail. My boost gauge hits 30psi, which means my true boost is probably around 27-28psi. It's maxed, but others will tell you they run 32psi or higher up here. They don't really, and they certainly don't make more power, but they'll swear by it until their no-time-slip dyno queen faces turn blue.
Old Sep 6, 2008 | 07:21 PM
emilebazin's Avatar
what size injectors to run e85
Old Sep 7, 2008 | 02:14 PM
32 max psi, is that for a stock turbo?
Old Sep 7, 2008 | 02:24 PM
EVO Nit3m4re's Avatar
a big setup? 1600 CC injectors with a 35R and a sweet fuel setup that would be awesome...
Old Sep 7, 2008 | 05:44 PM
EvoNiner1986's Avatar
I really can't wait to run e85!
I don't think my stock clutch will hold it too great though, so I'm going to wait until it goes out and then get an upgraded one.
Unless....The stock clutch is capable?
Old Sep 7, 2008 | 08:47 PM
Xolition's Avatar
It's fine as long as you don't launch it.
Old Sep 7, 2008 | 08:50 PM
Rnm's Avatar
Rnm
Just what I needed to hear considering I'm getting tuned for E85 this Tuesday and still on stock clutch lol, I can't wait!!
Old Sep 20, 2008 | 02:49 AM
emilebazin's Avatar
e85
what mods do I need for e85
Old Sep 20, 2008 | 09:05 AM
McLaren F1 2003's Avatar
i would assume that thats the minimum...
Old Sep 20, 2008 | 09:16 AM
EvoooB's Avatar
my thoughts... the state of MA needs to get their *** in gear and get this to us. i love corn!
Old Sep 20, 2008 | 01:15 PM
Minimum of 850cc, but I suggest 1,000cc. If you plan further turbo upgrades you might want to jump to 1,200cc.
Old Sep 20, 2008 | 01:19 PM
Most of the tuners who regularly tune and run E85 in their own cars seem to agree that the sweet spot with a stock turbo is 28psi. Above 28 the power increase is significantly less and the risks are significantly higher, IMO.
