e85 thoughts ?
Old Sep 5, 2008 | 05:20 PM
sdfontanini's Avatar
e85 thoughts ?
those of u already on e85 have ignition issues? coils failing? how bout cdi units going bad? How reliable is ur ignition system ?
Old Sep 5, 2008 | 05:39 PM
EVOlutionary's Avatar
Can you please tell us why you would ever think what type of gas you use will have anything to do with failures of electronics?
Old Sep 5, 2008 | 07:50 PM
Fine high boost high octane
Old Sep 5, 2008 | 08:04 PM
CBRicahrd's Avatar
has anyone had any issues with cold start with using E85???
Old Sep 6, 2008 | 07:07 AM
E85 has a flash point of 40 degrees
Old Sep 6, 2008 | 07:13 AM
Warrtalon's Avatar
Stock ignition, NGK BR8ES gapped to .019, no issues. An ignition amplifier would allow more gap for me, but everything works fine as-is.
I'm curious what made you so concerned that you'd make this thread.
Old Sep 6, 2008 | 07:18 AM
Robevo RS's Avatar
you got some pretty cold weather out there, right?
No issues what so ever even the tuned car?
If its that the case i cant wait untill they start selling in NJ...
Any extra modification neccesery to go E85?
Old Sep 6, 2008 | 07:58 AM
Warrtalon's Avatar
Yes, it gets quite cold out here, but because of that, they tend to give us E-70 more than elsewhere to help with cold starts. I haven't had a problem cranking yet, and I started in February when our winter is the worst. When it's really cold, and the car has been sitting a while, it does take a few cranks, but most of the time it fires up on the first try.
Only extra mod for me was larger injectors - 880s for stock turbo and 1000s for Green - along with my Walbro fuel pump, but everything else is stock.
Old Sep 6, 2008 | 09:02 AM
rahku's Avatar
i have a evo 8 some times takes me 2 starts but its well worth it
Old Sep 6, 2008 | 09:14 AM
evolution2186's Avatar
It has been taking me 4-5 tries before my car starts with e85. Thats with mild weather, in Missouri.
Old Sep 6, 2008 | 09:39 AM
Warrtalon's Avatar
That's not good - something is wrong.
Old Sep 6, 2008 | 09:51 AM
Could it possibly be because my plugs wires are screwed? I've noticed once when i changed my plugs that the metal tube inside of the plug wires that connects to the top of the spark plug stays on when i take it off. Could this be the cause? I never have misfires once its started.
Old Sep 6, 2008 | 09:55 AM
Robevo RS's Avatar
thank you !
Old Sep 6, 2008 | 11:51 AM
Warrtalon's Avatar
Do a quick swap of the stockers with another Evo just as a quick test.
Old Sep 6, 2008 | 11:55 AM
8thWonder's Avatar
There's a wealth of information in the alternate fuel section....
