Running water sound while driving
Old Sep 5, 2008 | 07:59 PM
Spish's Avatar
Update, page 2! Figured it out!
So I'm still pretty new to the Evo world so just let me know if anyone else has heard this. When I drive in the rain I can hear water draining, I know it sounds weird, its not the rain hitting the car, its a distinct running water sound. I thought maybe there were channels in the rain gutters on the roof letting water down but I don't see anything. Its sounds like its coming from the pillar between the front and rear doors. I can hear it while just sitting in the rain too, also I get a kinda musky smell in the car after it rains, I hope I don't have a leak. Anyone have any insight into this?
Old Sep 5, 2008 | 08:26 PM
RunRunRun's Avatar
Sounds like a leak
Old Sep 5, 2008 | 08:32 PM
vi3txdr34m5's Avatar
possibl leak check everywhere ... mildew smell is easy too find
Old Sep 5, 2008 | 08:44 PM
Spish's Avatar
Yeah, I was thinking possibly a leak too, anybody have any ideas where to start looking?
Old Sep 5, 2008 | 10:12 PM
heavens turbo's Avatar
if you have a sunroof, check the drains. if not, use a garden hose at where you think the water is coming in. there usually will be telltale signs of water intrusion. (like warped carpet, stains, etc.) good luck. theres a few waterleak posts on here also.
Old Sep 5, 2008 | 10:35 PM
Spish's Avatar
I don't have a sunroof, but I'll do the waterhose check and see what happens.
Old Sep 6, 2008 | 10:38 AM
JdMeVo4's Avatar
When you have your A/C on does it drip underneath your car? If not the weep hold for your evaporator core may be clogged.
Old Sep 6, 2008 | 10:57 AM
Spish's Avatar
Yeah, it drips. I only hear the noise when its raining. I searched all the places that people have posted up on here about water leaking and didn't see anything on my car.
Old Sep 6, 2008 | 11:53 AM
Slickdvl's Avatar
do you or have you ever had stereo equipment installed in the car? Usually a bad wire run from the engine bay through the firewall may cause a leak, and or through the trunk of the car. Check those areas out.
Old Sep 6, 2008 | 12:13 PM
Slickdvl's Avatar
seems like this guy may have a related problem...
https://www.evolutionm.net/forums/sh...d.php?t=367721
Old Sep 6, 2008 | 01:19 PM
alphadux_evo's Avatar
if you have a stock intake,,, try to check your air filter, maybe your filter is clogged already. same thing happened to me before.
Old Sep 6, 2008 | 01:57 PM
Spish's Avatar
I saw that post and checked where he had a leak and mine is good to go, no leaks visible.
Old Sep 6, 2008 | 02:39 PM
Spish's Avatar
Old Sep 22, 2008 | 05:22 AM
sprx19's Avatar
Seems wierd on a car this new, but maybe a leak in the heater core? Check your coolant level and see if you are loosing any.
Old Sep 22, 2008 | 01:08 PM
Spish's Avatar
Its ok, like I said its only when its raining, but when I look for anything wet on the interior I can't find anything. I looked in the trunk too.
