Disabling EBC Function On TruBoost
Old Oct 22, 2008 | 08:15 PM
porsherules911's Avatar
Well before I get flamed, the only reason why I ended up with the TruBoost gauge is because it was part of a package deal with the UEGO. I already have a mbc in my car so no need for this ebc. Anyway, had a friend install these for me and the wideband is working fine. The boost gauge however is not reading properly. It just shows a negative vacuum number of around -10.0. The gauge I highly doubt is defective because when I do start boosting, the negative value starts creeping back towards 0. If I'm in boost for a really long time, then it will go into positive numbers but barely. I set both A and B to off since the boost solenoid isn't connected. From asking around, people have been telling me the gauge should be able to display boost w/o the solenoid hooked up. Btw, the boost line is connected to the manifold line. Any ideas on what to do? I really don't want to have to go through uninstalling the gauge, selling it, then buying the regular AEM boost guage.
Old Oct 23, 2008 | 01:44 AM
Bumppp anyone?
Old Oct 23, 2008 | 10:23 AM
Redline-Z's Avatar
Veteran: Air Force
Please tell me why your not just running the AEM? I am nothing but happy with mine. It really help dial in the spool up with the crack pressure setting and taper is almost none existant. It's a win-win for the money and the failsafe is always nice to have.
Hook it up properly. I am sure it has something to do with the install. Happy boosting
Old Oct 23, 2008 | 11:03 AM
I told you I've had my manual boost controller already in the car. I wouldn't have gotten this gauge except I got it in a package deal with the UEGO. I don't care about having the failsafe and all the other features the TruBoost offers although they are good features to have. I am being told that regardless this gauge should work w/o hooking it up as a ebc.
Old Oct 23, 2008 | 11:26 AM
ROAD RACE VR-4's Avatar
I read on the AEM forums that if the solenoid is not plugged into the gauge it will show an error. You can plug the solenoid into the back of the gauge and leave it wrapped up under the dash or under the hood.
My solenoid is plugged into the gauge but its not hooked under the hood at the moment and the gauge gets its vacuum from the manifold.
Old Oct 23, 2008 | 11:59 AM
So your running this gauge just to show boost right? And its working for you? You can set both A and B maps to "off" and this will disable the solenoid and still should display boost.
Old Oct 23, 2008 | 12:13 PM
tnt1106's Avatar
hold left button down a few seconds. it will cycle from:
A) to B) to OFF) . once on OFF it will be a gauge only and not flash.
Old Oct 23, 2008 | 12:18 PM
yes i have it set to off and now the gauge just reads negative vacuum numbers and hardly moves. Right now I'm tapped into the manifold line for the boost so should I try somewhere else? Someone recommended tapping into the line running from intake manifold to bov?
Old Oct 23, 2008 | 12:30 PM
voltexct9a's Avatar
check your installation, i'm pretty sure it's that.
Old Oct 23, 2008 | 12:37 PM
4g63smokinall4s's Avatar
Thats not it.. Cause i hooked it up..
