Quick Question
Old Nov 30, 2008 | 12:20 PM
rolly1818's Avatar
Registered User
Quick Question
Can an ECU from another evo Ix work on my Evo ix?
Thanks in advance.
Old Nov 30, 2008 | 12:24 PM
wevo1985's Avatar
yes. just have to get the key programed
Old Nov 30, 2008 | 12:27 PM
rolly1818's Avatar
Registered User
Thanks a lot for a quick reply, but can u elaborate on getting the key programmed?
how do i do that?
Old Nov 30, 2008 | 12:28 PM
wevo1985's Avatar
the dealer will have to do that for you. they have the scanner for it.
Old Nov 30, 2008 | 01:06 PM
mump's Avatar
he is correct. it will work for about 2-3 seconds before the immobilizer shuts the car down. do what i did, put it in the car at the dealership and have them program all of your keys - not just the one you always use.
Old Nov 30, 2008 | 01:13 PM
gsrboi80's Avatar
Or get the immobilizer code of your current ECU and Change it to that in the new one using ECUFlash
Old Nov 30, 2008 | 01:45 PM
rolly1818's Avatar
Registered User
hmmmm...
firstly i am in Trinidad so no dealerships!
i have my old Rom, do i just flash over the existing rom on the new ECU??
BTW, will this stop my car from starting (the different ECU)?
i will post both roms from my ECUs a little later for some help if it does not work!
Thanks in advance guys.
Old Nov 30, 2008 | 01:47 PM
Evoryder's Avatar
If it's the same rom id then just swap out the ecu's and then load your current rom to it. Immobilizer is the key.
Old Nov 30, 2008 | 02:29 PM
rolly1818's Avatar
Registered User
no immobiliser key. never had one, the car was imported from Japan (hence no dealerships).
the reason all this started is cause i am trying to start my car, but no luck.
the car wont start and its throwing a code about the MAF sensor! i just wanna make sure the 'changed ECU' is not causing the problem.
the electrician advised that the MAF is damaged (lucky me dropped it).
Old Nov 30, 2008 | 02:44 PM
evoprime1's Avatar
well even if it was the ECU it would at leat start then die a couple seconds after
witch means its prolly not your ECU thats causing it not to start
Old Nov 30, 2008 | 03:05 PM
rolly1818's Avatar
Registered User
Thanks...well i guess i need to but a MAF sensor!!!
Anyone selling one? i need to get access to the 'For Sale' Forums.
Old Nov 30, 2008 | 05:51 PM
Evoryder's Avatar
Ok, so there is no immobo then you're going to have a lock smith program it for you. If there is a code about the maf then the maf is faulty. TRy cranking with the maf disconnected.
Old Nov 30, 2008 | 06:24 PM
rolly1818's Avatar
Registered User
car is tumbling, no spark or injector pulse. ECU is not seeing a signal for the MAF..
i think i need a new MAF right???
where can i get one ASAP?
Old Nov 30, 2008 | 08:50 PM
Evoryder's Avatar
check the forsale threads. I see maf's for sale daily.
I just realized that the new ecu doesn't need it's own immobilzer. You're using your original immobilizer from your original ecu. You connect to the new ecu and flash your rom from your old ecu...now if you don't even have that saved to a computer then you're screwed. Why do you need a new ecu?
Old Dec 1, 2008 | 03:39 AM
rolly1818's Avatar
Registered User
yeah i got my old ECU rom saved, but the immo code is the same so should not be a worry.
Will check the For sale forums.
Thanks again!
