bird chirp/cricket noise
Old Dec 10, 2008 | 01:23 AM
manofhonor's Avatar
ive posted about this before but didnt really get any help. when my car fully warms up and i get over 20-25mph, theres this strange noise that sounds like a bird chirp or cricket noise. its nothing with my clutch because its still there when my clutch is pressed and am coasting. it goes away when im at a stand still or get below the speed listed above. does anyone know what this is and how to fix it?
Old Dec 10, 2008 | 01:41 AM
whoang40's Avatar
There's a plastic trim piece that on the outside of your car that overlaps another one. It's kind of hard to describe unless I get a picture. If you look near the bottom of your windshield on the outside (corners you'll see a plastic trim piece). I put double sided 3M piece where the separation is for both corners. When you are going fast the air is going under the trim and making it vibrate like a reed on the end of a coronet instrument.
I had taken to the dealer for warranty work so they could look at it for the same issue. It took them over 3hrs. and they couldn't figure it out. I put 3M tape under the plastic trim piece and no more noise. Try that and update your post, good luck.
Old Dec 10, 2008 | 02:04 AM
Raistlin's Avatar
On occasion the plastic around the radio makes a sound similar to that. It only does it when driving though. Next time you hear it try pushing in on the top center or the corners.
Street gear
Nov 6, 2013 12:54 PM
mcjallen
Sep 26, 2011 01:03 PM
threefiftyse7en
Jun 21, 2007 06:52 PM
jdizzy
Aug 8, 2005 06:36 AM
ku7484
Apr 12, 2004 05:09 AM
