Harness bar vs. Roll Bar?
Old Feb 14, 2009 | 06:05 PM
justa4banger's Avatar
roll cage
Old Feb 14, 2009 | 06:09 PM
DJ Brett B's Avatar
Originally Posted by 05ah8james
I'm putting a harness bar in my car as an excuse to not carry people around in my car anymore .
You could just take the back seat out!! Then mount harness to rear floor. least expensive solution I can think of...
Old Feb 20, 2009 | 02:23 PM
anthony_86gt's Avatar
Are you looking into getting a harness to hold you into the seat better? The cheaper, easier, and more convenient way is to get a CG lock. This way you don't need a harness bar or roll bar to mount the harness to. This is what I do for the few track days I do a year.
Old Feb 20, 2009 | 03:41 PM
Smike's Avatar
Originally Posted by xtnct
Using a harness bar usually leads to using a racing harnesses (5 or 6 pt) that should not be used without a roll bar & racing seat.
Instead, either get a roll bar so that you can use the correct harness, or use a belt that is designed to be installed without a harness bar utilizing the stock mounting locations - such as the TUV & DOT approved Schroth with ASM harnesses.
Both a roll bar and harness bar make the rear seats unsafe for rear passengers, even if people put foam around it. For best human protection, you should be using the expensive dense stuff (like this: http://www.pegasusautoracing.com/pro...p?Product=2391), not the cheap foam stuff (like this: http://www.pegasusautoracing.com/pro...p?Product=2390).
With xtnct here.
PS - fixed my Schroth
Old Feb 20, 2009 | 05:25 PM
EvolNinja's Avatar
I was thinking of the harness bar too but I thought of the safety of the passengers so I guess I'm going to have to pass on this mod
Old Feb 20, 2009 | 06:17 PM
sing1002's Avatar
i want to get Harness bar too. but i know roll bar is much more helpful.
Old Feb 21, 2009 | 10:38 AM
IceHawk's Avatar
I was thinking harness bar, but, they thought about how bad it would hurt for a rear passenger if I happened to have a wreck.
Old Mar 1, 2009 | 08:47 PM
Evo6Point5's Avatar
Wide opinion is that using a harness with no cage is dangerous in a roll over etc.. this is true but at the same time you are probably at as much risk with standard seatbelt so it's a personal choice..
I've seen a rollover recently whereby the harness probably saved a life.. no cage.. but if you can afford it.. save up and go the cage anyway if you're looking to seriously track the car
Old Mar 1, 2009 | 09:53 PM
porsherules911's Avatar
I'm running a harness bar and like someone said on here it gives me an excuse to tell people you can't ride in the backseat unless you really have no choice. I'm not worried about being in a rollover accident plus I'm planning on getting a roll cage once this car isn't my dd and I can turn it into a track monster.
Old Mar 2, 2009 | 10:41 AM
koey03's Avatar
getting a roll bar is better
Old Mar 3, 2009 | 08:34 AM
-Evo Aaron-'s Avatar
ya i decided not to get one
EVO8LTW
Oct 27, 2016 05:43 AM
David Buschur
Dec 31, 2014 09:23 AM
boostedtres
Aug 27, 2008 02:37 AM
V8eatr
Oct 25, 2007 10:35 AM
Kyperion
May 17, 2004 11:47 PM
