car acted up
Old Apr 26, 2009 | 06:21 PM
EvoJoeIX's Avatar
car acted up
okay tonight was a nice night so i decided to drive my car a little bit. i took it down a twisty road and i let off the gas going into a turn, then as i go to get back on the gas the car seems to sputter and my check engine light comes on. after that i took it easy until i got home.
my question is what happend? could it have something to do with i was low on gas? not really low, my gas light wasnt on or nothing. its just weird, i never had this happen to me and i have no way of reading the code right now.
go figure, i havent got on my car for god knows how long, the night i do, something like this happens.
i hate this car, its time to sell
Old Apr 26, 2009 | 06:25 PM
Smike's Avatar
Pull the codes for us.
Old Apr 26, 2009 | 09:18 PM
SICK9's Avatar
did you check to see if you blew an intercooler pipe off.
Old Apr 26, 2009 | 09:26 PM
FedEvo8's Avatar
Try to pull your plugs out and see if they are all fouled up. Replace and regap if necessary...
Old Apr 26, 2009 | 10:51 PM
AKEVOIX's Avatar
yea hard to diagnose with no codes. get those and it will help
Old Apr 27, 2009 | 04:08 PM
EvoJoeIX's Avatar
car drove perfectly normal after that, so def not a intercooler pipe issue
i pulled the codes, it was a random misfire
my question is, why did the car sputter like it did?
never had that happen
Old Apr 27, 2009 | 05:41 PM
bigben's Avatar
Mine seems to do this every now and then. Has the ecu ever been tuned? If not, then it may need one. Def check the spark plugs and their gaps.
Old Apr 27, 2009 | 07:58 PM
EvoJoeIX's Avatar
yes tuned by CBRD, so i know theres no problem there
ill pull the plugs when i get time
i have no time now for cars that i started racing motocross again
Old Apr 27, 2009 | 11:43 PM
awalk9905's Avatar
I've had this happen to me on the track. I had around a 1/4 tank and it bogged in a high g turn... about a half a lap later the gas light came on.
Definitely check the codes because I don't remember any coming on.
Old Apr 28, 2009 | 07:14 AM
cfdfireman1's Avatar
Sounds like it's time for an "Italian tune up". Evos run rich and need to be blown out once in a while.
Old Apr 28, 2009 | 07:18 AM
mx4life85's Avatar
Did you ever replace your plugs? I had the exact same thing happening every time I punched it.
I had to replace my stock plugs with 1 step colder plugs. Then it quit misfiring.
And your making about the same hp as me, so it wouldn't surprise me if that was the culprit.
http://www.extremepsi.com/store/cust...&cat=567&page=
Old Apr 28, 2009 | 11:11 AM
danameisoj's Avatar
my car does the same thing every once in a while ... but 03's are plagued with the missfire codes.
my car sputters.. cel comes on but then drives normal.. i cant explain it either.
Old Apr 28, 2009 | 11:54 AM
boostless's Avatar
sounds like fuel starvation. if youre low on gas and go around a turn sharply you starve the fuel pump. If it acted normally after, go with at least half a tank of gas and see if it does it again.
Old Apr 28, 2009 | 11:58 AM
EvoJoeIX's Avatar
the car and plugs only have like 27000 miles on them, they are platinum plugs so i doubt thats the issue since it doesnt do it everytime i get on it. it only happend that one time.
i think it was gas starvation.
Old Apr 28, 2009 | 04:26 PM
oneofakindtrini's Avatar
Have you checked you plug gappings?
