Start up problem & service engine light
Old May 18, 2009 | 09:14 PM
D4o's Avatar
D4o
I started my car after I got out of work, it didn't want to start at first and made some kinda grinding & misfire sound.. I checked the engine oil and it looked a little below the line so I added more oil.. Then it started ok after but the service engine light turned on. I drove it home and waited about 2 hours.. Checked the oil which is now over the line a little bit, it turned over fine and the service engine light wasn't showing anymore. I was thinking if this problem had to do with the mobil 1 5-30 oil i'm using.. Should I change to a different kind of oil ASAP?
Old May 18, 2009 | 09:16 PM
bluebanana23's Avatar
pull the code at auto zone
Old May 18, 2009 | 09:18 PM
D4o's Avatar
D4o
It's not showing the code anymore
Old May 18, 2009 | 09:24 PM
helps to read the whole thing huh i wouldn't worry much about the 5w-30
Old May 19, 2009 | 02:27 PM
D4o's Avatar
D4o
I work next to a mechanic shop, and during my break time one of the guys over there told me that it sounded like something was wrong with my starter when he heard my car yesterday. It does it once in a while, not really everyday though. Should I look into changing my starter to be safe?
Old May 19, 2009 | 02:43 PM
quick silver 8's Avatar
I have the same problem, it's the starter. Change it asap cause it can mess up the flywheel
Old May 19, 2009 | 04:34 PM
D4o's Avatar
D4o
Thanks
Old May 19, 2009 | 08:40 PM
D4o's Avatar
D4o
I just tried to start it and all I hear is the whine from the starter motor, but the engine isn't making the turning over sound at all.
Old May 19, 2009 | 08:45 PM
T_Jochum24's Avatar
Sounds like the armature in the starter motor is no longer engaging into the flywheel. Logic says replace the starter
Old May 20, 2009 | 06:44 AM
no cruise's Avatar
change the starter.
Old May 20, 2009 | 08:57 AM
D4o's Avatar
D4o
I'm getting a new starter by the end of the week, I also bought Redline MT-90 for the tranny and Redline 75-90 GL-5 for the Transfer case & diff. Also got some new NGK BPR7ES plugs!
Originally Posted by no cruise
change the starter.
Old May 20, 2009 | 07:29 PM
EVOKRAZY8's Avatar
No all i use is Mobil 1 its the best
Old May 20, 2009 | 09:55 PM
abdizzle's Avatar
Dunno about where you live but most auto part chains no longer provide code readers. They were involved in a ton of lawsuits over people pulling codes and replacing parts that did not resolve the issue so most decided to only offer them in store for purchase.
dibbywsr
Lancer Engine Tech
10
Nov 1, 2012 07:01 AM
XK120
Sep 10, 2012 09:06 AM
poof101
Jan 13, 2012 08:42 AM
PhantomFreak
Lancer Engine Tech
17
Jul 10, 2008 10:24 PM
05evoGSR
12
Sep 13, 2007 06:27 AM
