****Car thinks keys are in ignition please help****
Old May 21, 2009 | 10:52 PM
headrec's Avatar
Hey
I was installing a turbo timer and while doing it the car started making the beeping noise when the door is open and the car has the keys in the ignition. I'm guessing I accidently grounded out the wire to the 'key in ignition' beeper. Anyone know what color the wire is or anything they could add to help to the situation. I'm going to go out there and check it out again in a minute but any help would be appreciated. Thanks!
Old May 22, 2009 | 12:16 AM
headrec's Avatar
Well figured it out.
There little plastic peice on the side of the ignition and when the key is in it disconnects two contact points that bridge two connections that indicate whether the key is in the ignition or not. It's a green wire on each side of the contacts. The plastic piece broke some how and I am planning to go to the dealer to get a new one. Messing with cars can be a pain in the *** haha. Just in case anyone comes across the thread in a search the plastic piece attaches with 2 small screws and when removed you can remove the two contacts as well as the bridge. I'm going to order a new 'base' and 'bridge' piece and hope for the best. Otherwise I plan to just bypass it. I hate the door buzzer sound anyway.
Old May 23, 2009 | 10:31 AM
EvolNinja's Avatar
glad you figure it out.
CodyL
Jun 3, 2022 03:59 PM
ScubaStevo
Oct 13, 2016 02:36 PM
EvotechS14
May 12, 2016 05:43 PM
wazzelby
Sep 9, 2012 07:47 PM
recompile
15
Mar 4, 2008 10:39 AM
