WHY does my evo shut off when the AC's on!
Old Jun 22, 2009 | 09:24 AM
rush63's Avatar
Back to basics. Try cleaning your throttle body and check if the servo motor is still doing its job.
Old Jun 22, 2009 | 10:07 AM
JediGillTees's Avatar
Former Vendor
Originally Posted by 03evokid
Well i have a AEM intake. And stock piping i had a stock BOV now i have a blitz bov still is doing it! i dont think there is any leaks anywhere i guess im goin to have to do a check for them
I'm not even joking when I tell you this but please remove the AEM intake and put the stock snorkel back on. You can keep the filter just change the Intake pipe. I've had this exact problem and I'm amazed at how crappy the AEM intake is.
It turns out that the stock snorkel has gill like ridges along the walls that help the MAF read the air better thus causing better idle. Not sure how exactly it works but give it a try. It worked for me.
Old Jun 22, 2009 | 10:12 AM
GPTourer's Avatar
I agree. Either that or change the snorkel back like JediGillTees says. My Eclipse used to do the same thing, but they are notorious for their ISC's going bad. I also had my idle speed raised to 1000 because of my cams. No more stalling with the A/C.
Its way to hot in Alabama to be ****ing around without A/C, too.
Old Jun 22, 2009 | 10:21 AM
Boricua_Evo's Avatar
...Yea it's about 135 degrees here in Kuwait, A/C is our best friend...
1 more month to go!!!
Sorry to get off topic... back to engine shut off...
Old Jun 22, 2009 | 07:26 PM
ernald711's Avatar
mine used to do this a long time ago. a grounding kit works wonders. you'd be surprised.
Old Jun 22, 2009 | 08:29 PM
Adam@MMS's Avatar
A little gratuitous help... if this is a cam/tune issue the idle should respond positively to raising the initial amount of air that the idle stepper motor lets in during an a/c on condition. It's under the idle tables in Ecuflash. "Initial ISCV position" I believe. Increase the bottom two columns of the table by 30% or so and see what happens. Also raise the target idle rpm for an a/c on condition.
Old Jun 22, 2009 | 09:35 PM
PwrEvo's Avatar
Mine does the same thing, when the a/c is on and I press the clutch the car just shuts off. This all started after my cam install. Also does anyones elses pcv valve rattle? This also happend after cam install. Haven't been able to get my car tuned ever scince.
Old Jun 23, 2009 | 01:54 AM
yahu's Avatar
People - get your cars tuned after cam installs as they can affect idle significantly (depending on the cams). Either do it yourself or go to a tuner. Also, a tune after an intake is sometimes good as some intakes really mess with how the MAF reads.
Old Jun 23, 2009 | 05:53 AM
rlui0514's Avatar
Originally Posted by Mojo Motorsport
Bigger cams can do that to you. Probably not your problem but I thought I would mention it.
+1 on bigger cams happen to my friend also but after a tune he was fine...
Or possibly not properly grounded or a bad ground somewhere after a mod
Good Luck !
Old Jun 23, 2009 | 09:04 AM
Mellon Racing's Avatar
usually it's caused by a poor tune
Old Jul 26, 2009 | 09:36 PM
D-VO's Avatar
What kit are you using? What are your grounding points?
I've only noticed this on deceleration, brake is depressed, <2500 rpm, and with "max AC" on (not just AC).
Old Jul 26, 2009 | 09:48 PM
GRNCT9A's Avatar
Its the cams. I just installed 272's and it idles at -10psi. It should be around -19psi. Whenever you drive and stop, your boost will most likely creep to -4 or -6psi and it'll cause the car to stall out alittle. You have to adjust your tune mainly in the idle section and increase your iscv intial step postion AC on and AC off in the 77 and 82 engine tempcolumn. Bump up your timing at idle too.
Old Jul 26, 2009 | 10:47 PM
big block ix's Avatar
My dash dims a little when I turn the AC on, and the idle drops a couple hundred Rpms..
Everyone I know has the same idle issue when they turn the AC on
Old Jul 27, 2009 | 06:28 AM
afamde's Avatar
I'd have a tuner look it over
Old Jul 27, 2009 | 06:33 AM
redleg225's Avatar
Go to TTP.
