WHY does my evo shut off when the AC's on!
Old Jun 21, 2009 | 07:54 PM
03evokid's Avatar
When I put the AC on and and im driving the car gets really sluggish. And then when I push the clutch it when I come to a light it just shuts right off. And if its on the car wont even start. SOMEONE HELP i live in GA and its like 103 out everyday
Old Jun 21, 2009 | 07:59 PM
unsungboxer's Avatar
hmmm, this is probably something that needs to be properly diagnosed, but here goes:
The AC adds load to the engine when it runs, the ECU should bump up the idle to compensate for this. If your car is having trouble idling due numerous reasons, the added load of the AC could cause it to die.
My first guess would be some sort of vacuum leak. This could be a loose fitting, or a hose that came unplugged. It could even be a blow off valve that isn't sealing properly. If this is occuring, you would likely notice your car having rough starts, rough idle, and sometimes sluggish acceleration off of idle, esp when cold.
I have also seen engines die when the fan from the AC/Radiator come on, usually happens with an open-element filter positioned too closely to the fan.
Thats all i have off the top of my head. Good luck!
Old Jun 21, 2009 | 08:02 PM
03evokid's Avatar
Well i have a AEM intake. And stock piping i had a stock BOV now i have a blitz bov still is doing it! i dont think there is any leaks anywhere i guess im goin to have to do a check for them
dunk186's Avatar
Any mods?? Mine does the same thing, but I know it's cause I need to be retuned
Old Jun 21, 2009 | 08:07 PM
03evokid's Avatar
Hks 280s
aem intake
epm dump
255 fuel pump
twindisc clutch with lighter flywheel
manual boost controler!
Old Jun 21, 2009 | 08:17 PM
Adam@MMS's Avatar
Bigger cams can do that to you. Probably not your problem but I thought I would mention it.
Old Jun 21, 2009 | 08:38 PM
Gumby56's Avatar
bigger cams for some reason dont pull vaccum and once vaccum is low call will stall out ... for instance my buddy has 280s and and its pulls very little vaccum .... so basically it may be cause you need to get a better tune to compensate for huge cams
Old Jun 21, 2009 | 08:39 PM
03evokid's Avatar
hm tru im just on a street emailing tune!! I think i might take u up on this and start saving for a better tune i guess!!
Old Jun 21, 2009 | 08:43 PM
GreedyE8's Avatar
This same problem happens to me, only my car doesn't die. It just idles very rough and at a very low rpm
Old Jun 22, 2009 | 08:43 AM
Boricua_Evo's Avatar
Is your BOV recirculated or venting towards the Air? Also your AEM intake should have have a smaller pipe for the recirculation of the BOV if it is not covered properly it, your stalling can be the cause of that as well...
Just throwing out some options bruh! GL
Old Jun 22, 2009 | 08:52 AM
yahu's Avatar
So did this just start? Have you installed anything recently, such as the bigger cams? What about the email flash, did you just do that? You most likely need a good tune to sort this out if it isn't in fact a leak somewhere.
Old Jun 22, 2009 | 09:06 AM
03evokid's Avatar
well ijust got the bov and it was doing it with the stock one b4.. And stated with the cams bc i put alot of stuff all in then got the tune and it started
Old Jun 22, 2009 | 09:17 AM
Hmm... interesting, please let us know when this gets fixed and what you did to remedy it. As others have mentioned check that tune, over the email tunes can be a little iffy!
Old Jun 22, 2009 | 09:18 AM
1d10t's Avatar
I too live in GA. Its hotter than friction from between a fat girls thighs.
Hey man, could be your tune for idle with a/c on n ecuflash!
ps dont post this issue on IA
Old Jun 22, 2009 | 09:20 AM
Live4Redline's Avatar
I agree... look at the tune.
