backfire
Old Aug 16, 2009 | 07:45 PM
kmartizdatruth's Avatar
backfire
been having some problems with the car for the past 2 days...all of a sudden once i hit boost over 20+lbs the car starts to backfire out the exhaust..i've checked everything mechanical on the car and even swapped out the spark plugs....anyone with any suggestions?
Old Aug 17, 2009 | 05:22 AM
grillpt's Avatar
List of mods?
Are you tuned?
Old Aug 17, 2009 | 07:00 AM
255lph fuel pump
upper and lower ic pipes
intake
forge adjustable bov
bc 272 cams
tbe
o2 housing
megan exhaust manifold
exedy clutch
mbc
and tuned
Old Aug 17, 2009 | 11:40 AM
please feel free to throw any ideas out there
Old Aug 17, 2009 | 03:42 PM
blkmkIII's Avatar
thats not a "backfire"
Old Aug 17, 2009 | 03:45 PM
Duh Panda's Avatar
fuel cut probably..
Old Aug 17, 2009 | 05:11 PM
why would the fuel be cutting then? any ideas on that one that could lead me to fixing this problem
Old Aug 17, 2009 | 07:57 PM
Wht9er's Avatar
could be getting knock and your ecu is pulling timing. Wrong plugs? should go a step colder with those mods. Maybe you need to close up the gap a bit on your plugs even to 24. coils may not be producing a strong enough spark in which you may need an amplifier such as an hks dlii or okada plasmas or something of that nature. just throwing out a few things it could be.
Old Aug 17, 2009 | 08:11 PM
thank you for the tips i will try that tomorrow right after work and let you know how it works out
Mackman
Apr 19, 2017 08:04 PM
Awd_evo
14
May 26, 2016 01:33 PM
evox_dev
May 24, 2015 07:36 AM
Dbzguy
Jul 10, 2012 05:19 AM
Deannn
31
Feb 15, 2012 05:00 PM
