rain makes the car stutter and rough idle?
Old Aug 20, 2009 | 09:00 AM
PHDoc19's Avatar
When it rains, atmospheric pressure is low, meaning there is a lower oxygen content in the air. You can probably figure out the rest.
Old Aug 20, 2009 | 10:25 AM
StreetEvo's Avatar
Just a suggestion, Unplug the cam pos sensor and see if it has any water/corrosion in the connector. If it does, clean the water/corrosion out and then fill the connector with di-electric grease. I had a couple of cars come in with a bad connection to CMP sensor when I was working for Mitsu.
Old Aug 20, 2009 | 01:21 PM
tsidrift1's Avatar
Ill give that a try, Cause when it happens to me, the car barely wants to drive.
Old Aug 22, 2009 | 08:11 PM
t3gr4's Avatar
Like everyone said, it's most likely water going in. It happen to my old car once.
Old Aug 23, 2009 | 09:32 PM
mitsubishifreak's Avatar
+1 on water on plugs/coils combo.depending on where filter and intake are located water on/in mass would also be a nono.
Old Sep 12, 2009 | 03:47 PM
jokietunedEVO's Avatar
Its water in the maf had same exact problem
Old Dec 3, 2012 | 08:07 AM
Ev0VII's Avatar
Originally Posted by Kins
What hood are you running? Stock?
What plug cover are you using?
Sounds like plug leads are getting damp/wet.
I would look there first.
I have an evo 7 hood with the vent and my cold air sits right there. And after rain last night it started an died out. Then I started it again and it ran...barely. But after it warmed up it ran fine. Just had a hard time every time I started it for a day after. And it threw a code p0121. Throddle position sensor. Wonder if that code will go away?:/
Cirielmd
Jul 16, 2017 05:02 AM
Greyfax
Aug 8, 2016 06:15 AM
Jonno99
Sep 25, 2015 02:48 PM
terrorz75
Evo X How Tos / Installations
Feb 25, 2013 05:21 AM
ilikeppie
11
Jul 6, 2012 10:58 AM
