wideband install question
Old Sep 7, 2009 | 06:44 PM
btownsoccer22's Avatar
I just ordered a innovate wb and was wondering to weld a bung on the downpipe do you have to take the downpipe off or can my car just go on a lift and it be welded right there?
Old Sep 7, 2009 | 06:48 PM
wevo1985's Avatar
i always take mine down. its easier to drill the hole that way.
Old Sep 7, 2009 | 06:51 PM
McLaren F1 2003's Avatar
^^+1
but it really depends on who is doing the work
Old Sep 7, 2009 | 06:52 PM
SyZyGy1394's Avatar
See, I told you Huy. Especially since you want it at 3 o'clock...
Old Sep 7, 2009 | 06:55 PM
SyZyGy1394's Avatar
Lol wut?
MEVOLV3's Avatar
Correct me if I'm wrong, but don't you want the sensor mounted above a horizonal plane?
Old Sep 7, 2009 | 07:00 PM
SyZyGy1394's Avatar
Yes because of condensation.
Old Sep 8, 2009 | 12:00 PM
Sil'vr-Boi6's Avatar
For safety & performance sake, you definately want to remove the downpipe--then weld it.
Previous owner of my car totally screwed the weld job. I had to buy a complete downpipe and redo the job. Now I'm getting a CEL due because I have a resonator.
^Like stated above --3 o'clock is what you want. Improper weld might result in CEL.
Old Sep 9, 2009 | 08:20 AM
raginghadron's Avatar
To expand on this, you want it no less than 10˚ and no greater than 75˚ on the vertical plane (inclination).
Old Sep 9, 2009 | 09:25 AM
stockevo03's Avatar
Can you do it without taking off the dp? YES Would I do it that way? NO
Why cut corners when you do that all your doing is leaving room for something to go wrong
Old Sep 9, 2009 | 09:37 AM
SyZyGy1394's Avatar
I just don't understand how people think they can drill a hole at the proper angle on the downpipe and properly weld the bung ALL AROUND while its still mounted on the car.
Old Sep 9, 2009 | 09:43 AM
stockevo03's Avatar
I think you are confusing Can it be done with Can it be done properly and work and be reliable
Old Sep 9, 2009 | 09:50 AM
SyZyGy1394's Avatar
I see no point in cutting corners, especially on something that is used to tune your car.
Old Sep 9, 2009 | 09:59 AM
stockevo03's Avatar
Ya I am agreeing with you refer to post above
Old Sep 9, 2009 | 10:27 AM
BluEVOIX's Avatar
I'd suggest marking the place you want to put the bung while the downpipe is on the car. This way you have it positioned correctly in respect to the downpipe bolted on the car.
Then after you mark the angle/spot. Remove the downpipe, drill the hole and weld the bung.
As for the angle dont go less than 3:00 or 9:00 position but at the same time dont go too high where it will hit the underbody etc... during bumps or hard cornering.
740 Turbo Brick
15
Feb 21, 2017 04:11 AM
Bman513
Aug 10, 2016 01:24 PM
brainhulk
18
Mar 4, 2009 06:03 PM
SoR
Aug 6, 2004 07:47 AM
